What package ? 1206 or larger should be fine anyway.derkom wrote: Sun Jul 18, 2021 7:04 pmI would not expect that to be able to handle anywhere near the required current, but maybe @exxos should take this one.sandord wrote: Sun Jul 18, 2021 6:01 pm I've done a quick search at a parts store and found 4.7 µF 50V 10% ceramic caps measuring only 1.6 x 3.2 x 1.6 mm (I know, SMT). I find it hard to believe that these even smaller caps will do. But sure, specs are specs, right?![]()
Monitor recapping and low ESR
Re: Monitor recapping and low ESR
Just my two cents i would rather have a capacitor rated at 105c for 2000hr than any 85c capacitor at any hours
Tom
Tom
I've looked up the dimensions of a 1206 package and it's supposed to be 3.0 x 1.5 mm so the cap I found is even a little bit larger at 3.2 x 1.6 mm.
Here's the spec sheet by the way, if you're interested:
https://asset.conrad.com/media10/add/16 ... mm-1-s.pdf
Yeah, I agree. These devices aren't going to run for that many hours anyway and better resiliency for the periods they will is much more important.Tomswork wrote: Mon Jul 19, 2021 1:25 am Just my two cents i would rather have a capacitor rated at 105c for 2000hr than any 85c capacitor at any hours
Tom
I just saw the "1206" in the URLsandord wrote: Mon Jul 19, 2021 11:30 amI've looked up the dimensions of a 1206 package and it's supposed to be 3.0 x 1.5 mm so the cap I found is even a little bit larger at 3.2 x 1.6 mm.
Just for reference, this is where I'll end up. I shopped a commercial picture of the ceramic cap into the photo, maybe it's even smaller in reality:
Measure the pad and also check around it see if anything will short it is close to the edge or put some masking on it to insulate it
Tom
Tom
Thanks for the advice. If all goes well, they'll be in the mail tomorrow. I might post a picture of the final result.Tomswork wrote: Mon Jul 19, 2021 3:40 pm Measure the pad and also check around it see if anything will short it is close to the edge or put some masking on it to insulate it
Tom
sandord wrote: Fri Oct 26, 2018 9:49 am I selected low ESR caps as much as possible.
Commodore 1084S-P1 recap list PCB Part Type Specs Remarks Brand/model Srs Ripple Life Shop =========================================================================================================================================================================================================================================== Neck 2136 Elcap 200V 4.7µF 85C ->400V United Chemi-Con EKXE401ELL4R7MJ16S KXE 225 mA 12000h https://nl.mouser.com/ProductDetail/United-Chemi-Con/EKXE401ELL4R7MJ16S?qs=sGAEpiMZZMtZ1n0r9vR22e66vF2fXFUFUKOEkjD%2fyxS3cMS4aiMqHQ%3d%3d 2141 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d Main 2601 Elcap 16V 100µF 85C Panasonic EEU-FR1C101 FR 280 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1C101?qs=ob%252bdNz2%252bYEhUA1aQKNasqg%3d%3d 2291 Elcap 16V 1000µF 85C Panasonic EEU-FR1C102L FR 1.56 A 9000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1C102L?qs=sGAEpiMZZMtZ1n0r9vR22fJqYs4ddJyTvbFsgf7RFzA%3d 2604 Elcap 50V 1µF 85C Nichicon UHE1H010MDD UHE 30 mA 5000h https://nl.mouser.com/ProductDetail/Nichicon/UHE1H010MDD?qs=sGAEpiMZZMtZ1n0r9vR22e0BBN1kF1oiuvGryroGz0U%3d 2647 Elcap 25V 4.7µF 85C Nichicon UPW1E4R7MDD UPW 180 mA 2000h https://nl.mouser.com/ProductDetail/Nichicon/UPW1E4R7MDD?qs=sGAEpiMZZMtZ1n0r9vR22UXbiauPutPBiV%2foTctGsDo%3d 2669 Elcap 50V 10µF 85C Panasonic EEU-FR1H100B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H100B?qs=tfZGHB2PWd1xuGJO0KXeNw%3d%3d 2301 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2361 Elcap 50V 10µF 85C Panasonic EEU-FR1H100B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H100B?qs=tfZGHB2PWd1xuGJO0KXeNw%3d%3d 2328 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2327 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2640 Elcap 16V 100µF 85C Panasonic EEU-FR1C101 FR 280 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1C101?qs=ob%252bdNz2%252bYEhUA1aQKNasqg%3d%3d 2697 Elcap 16V 47µF 85C ->25V Panasonic EEU-FR1E470H FR 280 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1E470H?qs=sGAEpiMZZMtZ1n0r9vR22fPWwtj8kO8a%2fzgYRLdr2SePr5fsnSkkOQ%3d%3d 2696 Elcap 16V 47µF 85C ->25V Panasonic EEU-FR1E470H FR 280 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1E470H?qs=sGAEpiMZZMtZ1n0r9vR22fPWwtj8kO8a%2fzgYRLdr2SePr5fsnSkkOQ%3d%3d 2272 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2274 Elcap 16V 100µF 85C Panasonic EEU-FR1C101 FR 280 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1C101?qs=ob%252bdNz2%252bYEhUA1aQKNasqg%3d%3d 2268 Elcap 50V 1µF 85C Nichicon UHE1H010MDD UHE 30 mA 5000h https://nl.mouser.com/ProductDetail/Nichicon/UHE1H010MDD?qs=sGAEpiMZZMtZ1n0r9vR22e0BBN1kF1oiuvGryroGz0U%3d 2573 Elcap 63V 1.5µF 85C ->100V Nichicon UKL2A1R5KDD UKL 23 mA 2000h https://nl.mouser.com/ProductDetail/Nichicon/UKL2A1R5KDD?qs=sGAEpiMZZMtZ1n0r9vR22SMYX67SZ2TeOVgMK0G64G4%3d 2571 Elcap 35V 680µF 85C Panasonic EEU-FR1V681L FR 2.47 A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1V681L?qs=sGAEpiMZZMtZ1n0r9vR22fJqYs4ddJyTNfazGjwDasg%3d 2560 Elcap 35V 220µF 85C Panasonic EEU-FR1V221 FR 950 mA 6000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1V221?qs=tfZGHB2PWd1qntTD%2fFg9QQ%3d%3d 2561 Elcap 35V 220µF 85C Panasonic EEU-FR1V221 FR 950 mA 6000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1V221?qs=tfZGHB2PWd1qntTD%2fFg9QQ%3d%3d 2563 Elcap 50V 470µF 85C Panasonic EEU-FR1H471 FR 2.26 A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H471?qs=sGAEpiMZZMtZ1n0r9vR22f2plZjWOZXTu0LqHMfIqXE%3d 2269 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2266 Elcap 25V 4.7µF 85C Nichicon UPW1E4R7MDD UPW 180 mA 2000h https://nl.mouser.com/ProductDetail/Nichicon/UPW1E4R7MDD?qs=sGAEpiMZZMtZ1n0r9vR22UXbiauPutPBiV%2foTctGsDo%3d 2512 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2515 Elcap 250V 1µF 85C Panasonic ECA-2EM010 M 34 mA 2000h https://nl.mouser.com/ProductDetail/Panasonic/ECA-2EM010?qs=sGAEpiMZZMtZ1n0r9vR22ZJeXBnf%252bMH2XDsezkoHGhc%3d 2511 Elcap 63V 2.2µF 85C ->100V Panasonic ECA-2AM2R2I M 30 mA 2000h https://nl.mouser.com/ProductDetail/Panasonic/ECA-2AM2R2I?qs=sGAEpiMZZMtZ1n0r9vR22ZGaUoI0JcRfCVPOCQ2yKp8%3d 2536 Elcap 50V 1µF 85C Nichicon UHE1H010MDD UHE 30 mA 5000h https://nl.mouser.com/ProductDetail/Nichicon/UHE1H010MDD?qs=sGAEpiMZZMtZ1n0r9vR22e0BBN1kF1oiuvGryroGz0U%3d 2526 Elcap 50V 1µF 85C Nichicon UHE1H010MDD UHE 30 mA 5000h https://nl.mouser.com/ProductDetail/Nichicon/UHE1H010MDD?qs=sGAEpiMZZMtZ1n0r9vR22e0BBN1kF1oiuvGryroGz0U%3d 2524 Elcap 50V 4.7µF 85C Bipolar Panasonic ECE-A1HN4R7UB SU 30 mA 2000h https://nl.mouser.com/ProductDetail/Panasonic/ECE-A1HN4R7UB?qs=rMMd5vBiahpkxAP40j04wA%3d%3d 2537 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2547 Elcap 63V 2.2µF 85C ->100V Panasonic ECA-2AM2R2I M 30 mA 2000h https://nl.mouser.com/ProductDetail/Panasonic/ECA-2AM2R2I?qs=sGAEpiMZZMtZ1n0r9vR22ZGaUoI0JcRfCVPOCQ2yKp8%3d 2541 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2520 Elcap 160V 10µF 85C Panasonic ECA-2CHG100 NHG 70 mA 2000h https://nl.mouser.com/ProductDetail/Panasonic/ECA-2CHG100?qs=sGAEpiMZZMtZ1n0r9vR22YuzYhk2RkTK9cQAJ%2f7o%252b7s%3d 2445 Elcap 50V 470µF 85C Panasonic EEU-FR1H471 FR 2.26 A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H471?qs=sGAEpiMZZMtZ1n0r9vR22f2plZjWOZXTu0LqHMfIqXE%3d 2451 Elcap 200V 47µF 85C Panasonic EEU-EE2D470 EE 1.1A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-EE2D470?qs=sGAEpiMZZMtZ1n0r9vR22dN7zJS18SGV9iCD0vMIFLk%3d 2447 Elcap 25V 470µF 85C Panasonic EEU-FR1H471 FR 2.26 A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H471?qs=sGAEpiMZZMtZ1n0r9vR22f2plZjWOZXTu0LqHMfIqXE%3d 2446 Elcap 25V 470µF 85C Panasonic EEU-FR1H471 FR 2.26 A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H471?qs=sGAEpiMZZMtZ1n0r9vR22f2plZjWOZXTu0LqHMfIqXE%3d 2452 Elcap 50V 22µF 85C Panasonic EEU-FR1H220B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H220B?qs=sGAEpiMZZMtZ1n0r9vR22eHFyjIavHtVdKguaoTFhyw%3d 2450 Elcap 50V 10µF 85C Panasonic EEU-FR1H100B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H100B?qs=tfZGHB2PWd1xuGJO0KXeNw%3d%3d 2416 Elcap 50V 10µF 85C Panasonic EEU-FR1H100B FR 250 mA 5000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-FR1H100B?qs=tfZGHB2PWd1xuGJO0KXeNw%3d%3d 2412 Elcap 400V 100µF 85C Snap-in Panasonic EEU-EE2G101 EE 2.06 A 10000h https://nl.mouser.com/ProductDetail/Panasonic/EEU-EE2G101?qs=sGAEpiMZZMtZ1n0r9vR22dN7zJS18SGVb6qEf80gQAc%3d 2422 Elcap 50V 1µF 85C Nichicon UHE1H010MDD UHE 30 mA 5000h https://nl.mouser.com/ProductDetail/Nichicon/UHE1H010MDD?qs=sGAEpiMZZMtZ1n0r9vR22e0BBN1kF1oiuvGryroGz0U%3d
I just subscribed to ask wether there is a mouser-project or Shopping cart That you can Share with me because i startet to recap my 1084S-P1 this week.
I would really appreciate cause it is a pain to select all of the caps.
Thanks a lot.
maddoc177
- Admin sponsor
I just buy a recap kit. Getting to deep into the brand of cap is heading for audiophile territory. You arent going to notice any difference beyond a point.
Main things to replace in a monitor are the bits that work hard. The transistors on the neck board, flyback and HOT. Using decent caps is worth it but mostly because they probably wont leak all over your board.
Fixating on ESR is not really worth it.
www.youtube.com/user/randyfromm/videos
Randy Fromm is the guy i learned most of this stuff from. Unfortunately his best videos are gone.
