Troed - progress
troed
Re: Troed - progress
Post by troed »
PaulJ wrote: 07 Nov 2018 19:22 Troed have you checked what state the processor is in.. is it halted.. held in reset etc. Used dragROM, or the atari drag cart to see if rs232 communications is possible? Checked all the clocks? just looking for some indication of non functional electronics.. What is it drawing for current. With no floppy and just a functioning main board it drew approx. 1.05 amps.
It's HALTed. GLUE produces syncs so clocks are good.
(I need to buy a USB-RS232 cable .. )
PaulJ
Post by PaulJ »
Initially my board would run for 400 ms and halt. I ended up fixing it by changing the glue. A week later I tried that glue in another 1040 and it worked fine. I don't know what conclusion one can draw from this other than the sockets suck.
Return to “ALPHA USER BUILDS”
