PaulJ Progress
Re: PaulJ Progress
You can't beat a good croc clip :D
PaulJ
Re: PaulJ Progress
Post by PaulJ »
Power applied!!.. no joy. Board draws 1.05 amps and most things appear to be working. The big gotha is the halt line which is low. I don't have a monitor connected since I ordered the un-fu*k converter.. boards, not shipping until the 15th. I have the diagnostics cart and serial connected. Couple of garbage characters on power up. Encouraging that lots of stuff appear to be running or in the right state so I'm off to chase the halt signal. I may need to shit rig a video cable. :cheer: :cheer:
Re: PaulJ Progress
Sounding promising so far. I'd check the MMu and Glue and Rom chips and sockets for good contact for starters.
Oh and check you have good clock signals on the shifter, CPU, etc.
Most of the time I had the CPU halted it was because of a loose connection on the GLUE.
PaulJ
Re: PaulJ Progress
Post by PaulJ »
All clocks look good... when I run TOS rom it halts quickly .. with the diag cart in it runs for ~sec.. going to check memory and acias..
PaulJ
Re: PaulJ Progress
Post by PaulJ »
New GLUE chip!!
R RAM O O.S. ROM C Color
K Keyboard M MIDI S Serial Port
A Audio T Timing D DMA Port
F Floppy Disk P Printer/Joy Ports H High resolution
J Hard Disk Write/Read (use SH204/SH205/Megafile)
G short BLiT test Y long BLiT test
L Real-time Clock
X Expansion Connector
Q Run all tests
Z Run internal tests (R,O,C,K,A,T,L,G)
E Examine/Modify memory
B Set RS232 rate
V toggle video output--50/60 Hz
? Help
Enter letter(s), and RETURN: R
Testing Ram
4M RAM Pass
Much better!!! :excited: :excited: :excited:
Re: PaulJ Progress
That's more like it, well done.
Now to make sure everything else works and to post a pic or vid of your choice of game running :D
Re: PaulJ Progress
:bravo: :cheers:
Clearly we have a good little team of people who are good at soldering and building stuff up :)
PaulJ
Re: PaulJ Progress
Post by PaulJ »
Guess I'm going to need to sh*t rig a video cable since the un-fu*kit boards will not show up for a couple weeks. Really helps when one uses good chips. :yay2: :yay2: :yay2: :yay2: :yay2: :yay2: :yay2: :yay2:
I6 Testing Bus Error handling
No (I6) error
Keyboard failed, connect RS232 terminal
Mega and ST Field Service Diagnostic Rev. 4.3
1990, Atari Corp.
4M RAM Keyboard rev. 0 60 Hz Version 1.4 UK PAL
L Real-time Clock
Q Run all tests
B Set RS232 rate
? Help
Testing Ram
* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *4M RAM Pass
1990, Atari Corp.
L Real-time Clock
Q Run all tests
B Set RS232 rate
? Help
Enter letter(s), and RETURN: O
ROM checksum test
TOS in ROM: although six ROMs are shown, there may actually be only two.
Version 1.4 UK PAL
checksum crc
H2 2097 C8D0
H1 2AAA FC91
H0 F6F2 A147
L2 9FC5 CA69
L1 305D 962A
L0 648B BBF2
Pass
1990, Atari Corp.
L Real-time Clock
Q Run all tests
B Set RS232 rate
? Help
Enter letter(s), and RETURN: T
Testing MFP, Glue timing, Video
Pass
1990, Atari Corp.
L Real-time Clock
Q Run all tests
B Set RS232 rate
? Help
rpineau
Re: PaulJ Progress
Post by rpineau »
:bravo:
Re: PaulJ Progress
Great work - looks like we have 3 alive now. :D
Second Forgottenmyname's comment - get a pic or video of your game of choice once you have video.
Exxos you now have three babies out there, how many more will be born?
Return to “ALPHA USER BUILDS”
