PaulJ Progress
Re: PaulJ Progress
PaulJ wrote: Mon Oct 22, 2018 6:03 pm Track 1 of GoTec loads it into ram and until I repower I 2.06 which I like much better that 1.04.. :cheer: :cheer: :cheer:
Yeah TOS206 is loads better OS.. not so good for games exactly , or anything for that matter on the ST :lol:
TOS206 decoding will be built into the new GLUE core eventually anyway.
PaulJ
Re: PaulJ Progress
Post by PaulJ »
exxos wrote: Mon Oct 22, 2018 5:57 pm
PaulJ wrote: Mon Oct 22, 2018 5:55 pm Bench6 is a match of Exxos post!! :yay2: :yay2:
How is it you have TOS206 running as the system ?!
Sure would be nice if on the next board it could be put in rom!!! :D :D :D
Re: PaulJ Progress
PaulJ wrote: Mon Oct 22, 2018 6:08 pm Sure would be nice if on the next board it could be put in rom!!! :D :D :D
Putting it in ROM isn't the problem, its decoding the address ranges... this needs to be done in the new GLUE core, which is a long way off.. need to get the blitter one working first yet...
PaulJ
Re: PaulJ Progress
Post by PaulJ »
exxos wrote: Mon Oct 22, 2018 6:09 pm
I realize its a space issue with current rom location that requires it to be moved which causes a decoding issue. Never the less without the change in decoding even if I burn a rom I can't use it.. :mad:
PaulJ
Re: PaulJ Progress
Post by PaulJ »
I guess for me a 1.04/2.06 would be the perfect combination of switchable versions. Would require more effort since the decode areas change but I consider it the optimum combination.
Re: PaulJ Progress
PaulJ wrote: Mon Oct 22, 2018 6:22 pm I guess for me a 1.04/2.06 would be the perfect combination of switchable versions. Would require more effort since the decode areas change but I consider it the optimum combination.
Thats what I did with the V2.2 booster...
http://www.exxosforum.co.uk/atari/last/V ... /index.htm
PaulJ
Re: PaulJ Progress
Post by PaulJ »
exxos wrote: Mon Oct 22, 2018 6:23 pm
Yes but its always been sold out. I have some of the 1.5 boosters and they work good but don't a thing for moving to 2.06..
PaulJ
Re: PaulJ Progress
Post by PaulJ »
Only thing to complete is getting then MIDI running. Just ordered OPTO yesterday so by the end of the week it should be here. Since the OWC box is not a permanent solution I'll have to look into mounting this puppy so it can easily be moved around.
Re: PaulJ Progress
Rack mount ;)
PaulJ
Re: PaulJ Progress
Post by PaulJ »
Could be, I do have a rack kicking around from some telecom equip I used to test STB's with.
Return to “ALPHA USER BUILDS”
