PaulJ Progress
Re: PaulJ Progress
Exactly. Think I will stick to the older versions.. Most of my stuff was done in version 4!
Re: PaulJ Progress
Heres the current status, except for the untried blitter and broken MIDI this puppy is totally finished.
- Attachments
- XXXX.jpg (336.51 KiB) Viewed 4437 times
Re: PaulJ Progress
I hope to try the blitter tomorrow, time permitting
Re: PaulJ Progress
Great work PaulJ
Will be good to see all greens on the table once you pop in the new opto.
Out of interest, a part from testing, what else have you been doing on your STF as you mention "lots of hours without issue"?
Re: PaulJ Progress
Careful not to blow your GLUE chip like the problem Forgottenmyname had at testing the Blitter.
Re: PaulJ Progress
Yep, I don't have any spare chips at all if I blow any of these upIcky wrote: Sun Oct 21, 2018 10:06 pm Careful not to blow your GLUE chip like the problem Forgottenmyname had at testing the Blitter.
Re: PaulJ Progress
Good luck Paul, really hope it works for you
Re: PaulJ Progress
I've been pulling together stuff from a few Gotek roms building the master flash disk for the stf, and making backup flashes on the utraS. I sorta have an issue with Gotek, I haven't make an index of the flash sticks so I spend some time searching. I have to come up with a solution for that. Over that I've been installing so of the apps.. installed MWC and played with that a while..Icky wrote: Sun Oct 21, 2018 10:04 pm Great work PaulJ
Re: PaulJ Progress
Do we know the problem Forgottenmyname ran into? I've been going over the schematics and haven't run into anything that's a problem yet. A lot of the lines are already connect to the socket and their not causing trouble. When I'm done reviewing the schematics I'll scope the signals to check for anything that doesn't look right. I have a Blitter I purchased from Exxos which must be STRONGER that a plain BLITTER I mean baby's got a sticker on it an and everything!exxos wrote: Sun Oct 21, 2018 10:18 pmYep, I don't have any spare chips at all if I blow any of these upIcky wrote: Sun Oct 21, 2018 10:06 pm Careful not to blow your GLUE chip like the problem Forgottenmyname had at testing the Blitter.But needs to be tried out.. I don't see any errors anywhere in the diagram.. but never know.
Re: PaulJ Progress
Yeah, sticker makes all the difference!PaulJ wrote: Sun Oct 21, 2018 10:51 pm I mean baby's got a sticker on it an and everything!![]()
The Blitter really supper charges the ST!! So I guess it will be close to see who's first to get a Blitter running!
Really it should be me to try it out, let it blow up my blitter first
