Video driver thoughts
sandord
Re: Video driver thoughts
Post by sandord »
Processing logic in your display may not scale that properly to your display's native res.
By the way, when watching the exact same pattern on an SC1224 you get the same result: moire, which is probably a result of the limited resolution of the mask.
Snap - I still have the large caps jumpered
Oh nevermind, I see them on the falcon as well..
Could be a monitor issue for me yes....
Icky wrote: Thu Nov 29, 2018 10:15 pm Snap - I still have the large caps jumpered
:bravo:
So I need to work on a new version of this video board next then.... onto version 3....
exxos wrote: Thu Nov 29, 2018 10:25 pm So I need to work on a new version of this video board next then.... onto version 3....
How far do we go on this until we realise its actually the shifter itself that causes some of the issues?
So what's the thoughts? Better video with the DAC or with the old RGB? Will check for myself tomorrow too, with the UBE and my LCD tv.
And will this make it to the Mongrel board? What do you think?
Icky wrote: Thu Nov 29, 2018 10:30 pm How far do we go on this until we realise its actually the shifter itself that causes some of the issues?
Well I know the shifter outputs are not great, they get amplified on the RGB transistors, its why I wanted to move to a DAC to clean up that issue..
I actually think the video now is loads better than on the Falcon, and its the same chip!
Forgottenmyname wrote: Thu Nov 29, 2018 10:31 pm So what's the thoughts? Better video with the DAC or with the old RGB? Will check for myself tomorrow too, with the UBE and my LCD tv.
I will definitely use this DAC on the next MB.
Only odd thing I seen so far is as I change the ST's voltage from 4V to 5.5V the video seems to break up .. will try and take a image...
Could you guys try changing the voltage also ?
Might just be a bad connection I have somewhere....
Will do tomorrow, may explain why my image was different slightly than yours, my psu is set at 5.1V at the moment.
