Video driver thoughts
Re: Video driver thoughts
Icky wrote: Thu Nov 29, 2018 9:23 pm
exxos wrote: Thu Nov 29, 2018 9:17 pm @ Icky, I wonder if you can try the normal RGB circuit, but lift out the BLACKing didoes D1,D2,D3 ?
Just in the process of getting the video uploaded of the motherboard driver circuit in play.
Then I may get time to lift the blanking diodes - non-Atari duties are calling tonight.
Well I did say it was dark - didn't realise how dark until I filmed it
Who is awesome :D :D :D
exxos wrote: Thu Nov 29, 2018 9:52 pm Who is awesome :D :D :D
Exxos is awesome - How did you do that :cheer: :cheer: :cheer:
sandord
Post by sandord »
It's Chris Norris!! :yay2: :dualthumbup:
Icky wrote: Thu Nov 29, 2018 9:54 pm Exxos is awesome - How did you do that :cheer: :cheer: :cheer:
I lifted that highlighted pin which, and linked to small wire from it to the BLANKing line...
So when BLANK is high, it selects D-RGB mode, when BLANK is low it selects A-RGB mode...
Technically the A-RGB lines are floating, but at this time of night I did not care, and it works anyway so :cheer: :cheer:
exxos wrote: Thu Nov 29, 2018 9:58 pm
Brilliant so it was blanking related :D
Question now is to compare original circuit against new DAC circuit to see improvement.
Icky wrote: Thu Nov 29, 2018 10:00 pm Question now is to compare original circuit against new DAC circuit to see improvement.
Sadly it looks the same :roll:
Mostly I was trying to get rid of the vertical noise lines in the drag bar but they are still there... Only now they seem to be flickering a little bit...
I do have some 40R resistors in series with the RGB outputs with 47pF on them.. so its not like its noise there...
Gave myself permission to upload a high res shot to illustrate this...
The thing is, I don't think I saw this on the Falcon video.. and its the same chip now :roll:
BTW - the jumper does up the brightness a little, not a great deal...
So, is this a similar issue to the “front porch”/“back porch” video generation issues that the early ZX81 ULAs had?
Basically in that case the ULA didn’t produce a “back porch” on the video signal so the TV/monitor circuitry couldn’t determine the base level of the signal. In the case of the ZX81 color TVs took the “white” level to be black and dimmed the display accordingly.
I guess that in this case the monitor could be taking a floating value as the black level, when the border is white. When it’s black then it emulates a back porch.
Well done guys. Looking better and better.
You'll get there with the quality thing Exxos, just take a bit of tweaking is all.
Will lift the pin tomorrow and catch up yet again, lol.
Still didn't fix the floppy drive problem, too busy with Fallout 76.
exxos wrote: Thu Nov 29, 2018 10:06 pm
It looks like your display is doing a great deal of “sharpening”. Lots of nasty halos!
