Video driver thoughts
Re: Video driver thoughts
GND (top) layer, nice solid route under and around the DAC...
VCC (bottom) layer...
I added in 2 more caps on VCC pins of the DAC since they are in stupid places.. Digital & analouge ended up mixed up as a result of it all.. but All likely better router than on the Falcon anyway.
PCB view...
I've ordered 10 PCBs and paid for UPS delivery.. Since the 1772 boards only went into production this morning, I have asked if those can be sent with the video boards so I hope to get both quicker then... £25 a go is a lot for UPS... but I should get the boards in a weeks time.. not 1-2months...
Just got a email saying the boards have been shipped :cheer: :cheer:
exxos wrote: Fri Oct 26, 2018 2:10 pm Just got a email saying the boards have been shipped :cheer: :cheer:
:D - Looks like you are building up quite a set of boards that I need Exxos :)
Put me down for the 1772 buffer board and this one.
EDIT: just need to think of a few other things to add from your wed shop to add to that order :)
Same for me, ready for when I get it fixed :roll:
Then time to print some more supports.
Icky wrote: Fri Oct 26, 2018 2:36 pm :D - Looks like you are building up quite a set of boards that I need Exxos :)
Yes :) When every chip on the board has a patch PCB on it, then our work is done! :lol:
exxos wrote: Fri Oct 26, 2018 3:17 pm
Agreed. I think we might have gone too far if we start putting patch boards on top of patch boards. :)
Icky wrote: Fri Oct 26, 2018 3:31 pm Agreed. I think we might have gone too far if we start putting patch boards on top of patch boards. :)
Likely will happen ;)
sandord
Post by sandord »
We could always turn to patch bays if we wanted :pullhair: :)
Hopefully the boards will come in a day or 2... What I will do is try to make one up for testing before anything else. No use you guys buying the chip and soldering it if the thing doesn't work ;)
