Video driver thoughts
Re: Video driver thoughts
Icky wrote: Tue Nov 27, 2018 7:25 pm I thought that too. Changed res and it still has that purple dark mode.
Odd if desktop doesn't work, but loading a game does :stars: :stars: :stars:
Does the diagnostic cart have a RGB test ?
exxos wrote: Tue Nov 27, 2018 7:33 pm Does the diagnostic cart have a RGB test ?
Yes there is a colour test. I also reverted to original configuration to compare.
Colour test using Diag cart with Video DAC board in place:
Colour test using Diag cart with original circuit in place:
How odd.. half looks like its not bright enough.. but doesn't explain odd colours getting mixed in...
maybe I have screwed up one of the RGB lines on the chip or something :shrug:
Also using DiagCart in original mode the background is blue with white text.
Using the Video DAC board the background is black with slightly yellow text.
Original:
Video DAC Board:
Well here is the diagram..
and the pdf...
https://www.exdwh.com/data/STV8438CV.pdf
There is also the wiring between the schematic and the actual device.. will try and post that shortly to check...
pinout for the package...
exxos wrote: Tue Nov 27, 2018 8:05 pm Well here is the diagram..
and the pdf...
I'll start to take a look. In the mean time here is the boot to desktop using the Video DAC board.
Is there any benefit from me duplicating the results at the mo? Or should I wait on assembling it?
Forgottenmyname wrote: Tue Nov 27, 2018 8:16 pm Is there any benefit from me duplicating the results at the mo? Or should I wait on assembling it?
I would build it, see if you have the same issues.. I mean maybe its a bad chip :shrug:
