Video driver thoughts
rpineau
Re: Video driver thoughts
Yes, that's a good idea, probably only needed for the bit 3 and 4 as after that the increase will be very small.
At last, an opportunity for a triple decker. Now do I put it over or under the ram board :D
Don't follow what you mean ?Forgottenmyname wrote: 19 Oct 2018 21:26 At last, an opportunity for a triple decker. Now do I put it over or under the ram board :D
Well I already have the shifter in the adaptor board for your ram expansion.exxos wrote: 19 Oct 2018 21:30Don't follow what you mean ?Forgottenmyname wrote: 19 Oct 2018 21:26 At last, an opportunity for a triple decker. Now do I put it over or under the ram board :D
oh yep :lol:Forgottenmyname wrote: 19 Oct 2018 21:37 Well I already have the shifter in the adaptor board for your ram expansion.
More of a final draft...
..with something like this...
rpineau
I'm not sure about C1, C2 and C3 inline with RGB, the Falcon has 75 ohm resistors inline to match standard line impedance for video signals.
Are you doing this to eliminate any potential DC in the signal ?
I'm doing it because that what it says in the datasheet.... I to am not sure why the falcon is wired up differently..rpineau wrote: 19 Oct 2018 21:56 I'm not sure about C1, C2 and C3 inline with RGB, the Falcon has 75 ohm resistors inline to match standard line impedance for video signals.
rpineau
Works for me .. I think the datasheet is probable more accurate than what was done on the falcon :)
Hopefully :) Easy to bridge them over if needs be anyway.rpineau wrote: 19 Oct 2018 22:12 Works for me .. I think the datasheet is probable more accurate than what was done on the falcon :)
Users browsing this forum: CCBot and 207 guests
