So by my calculation thats 480uF assuming those numbers are uF.
RESET circuit tweaks
Re: RESET circuit tweaks
Yes 480uf as both are in parallel.
PaulJ
No double cap here. Its a 10 ufIcky wrote: 10 Nov 2018 19:58Thanks Forgottenmyname - I notice your C3 is two caps in parallel. What value are they?Forgottenmyname wrote: 10 Nov 2018 19:51 If it helps, here's a photo of my Mega reset circuit, in case something is a different value to the schematic.
PaulJ
Does the second cap look factory or a user hack?
Just tried 470uF in parallel.
Its weird. Its just doesn't seem to be behaving as expected. Reset switch doesn't affect anything. Have checked and checked the circuit. I have two TL7705's so both of them cant be duff.
Just looking at the data sheet at the mo, the difference in CT will mean a longer reset delay if I am reading this correct, so just means a different delay. Maybe one of my Mega's is a little slow at starting and needed encouragement?
And now its gone back to the occasional bouncing inverted reset out after powering on again.Icky wrote: 10 Nov 2018 20:14 Just tried 470uF in parallel.
Being thick today but comparing schematics, mega values for C1 and C is .1uf but we are using 10nf.
Also bizarrely, the data sheet for the 7705 shows ref connected to VCC but on the mega drawing and the reset board it goes to gnd via a cap.
data sheet if useful
http://www.ti.com/lit/ds/symlink/tl7705b.pdf
Interesting spot. I just powered on the prototype circuit again and it seemed to work with pulses.Forgottenmyname wrote: 10 Nov 2018 20:27 Being thick today but comparing schematics, mega values for C1 and C is .1uf but we are using 10nf.
And now its back to no activity on inverted Reset. :headbang:Icky wrote: 10 Nov 2018 20:30Interesting spot. I just powered on the prototype circuit again and it seemed to work with pulses.Forgottenmyname wrote: 10 Nov 2018 20:27 Being thick today but comparing schematics, mega values for C1 and C is .1uf but we are using 10nf.
Users browsing this forum: CCBot and 7 guests
