1040 STF showing occasional rogue pixels
Re: 1040 STF showing occasional rogue pixels
sandord wrote: Fri Sep 28, 2018 3:22 pm RAMTEST says 171 OK passes, 0 fails.
:roll: Do you see the bad pixels on screen currently during the test ?
Have you tried a different monitor and shifter chip ?
sandord
Post by sandord »
exxos wrote: Fri Sep 28, 2018 3:39 pm
Currently, I'm at 623 OK passes. No bad pixels to be seen anywhere.
We've had this ST connected to three different monitors, same story everywhere.
I'm going to try with another shifter in a minute but I doubt that'll make any difference since the bad pixels stay bad as long as nothing writes to the the RAM at that spot. I don't think even the worst shifter could do that, render a specific pixel wrong over and over again.
Oh, I wanted to add that the bad pixels never flash (unless they're on a screen that is swapped by the program, like most games).
sandord
Post by sandord »
exxos wrote: Fri Sep 28, 2018 3:39 pm Have you tried a different monitor and shifter chip ?
I tried a different shifter: same story.
have you tried pushing down hard on each ram chip during YAART and see if anything happens.
sandord
Post by sandord »
exxos wrote: Fri Sep 28, 2018 4:07 pm have you tried pushing down hard on each ram chip during YAART and see if anything happens.
I just tried it on all chips of bank 0 (bank 1 is still disconnected). No errors.
sandord
Post by sandord »
I also tried a different MMU, no difference.
sandord
Post by sandord »
YAART doesn't show any bad pixels on 512 kb.
Very strange.
You could try diagrom if you can program roms.
https://www.exxosforum.co.uk/forum/viewt ... =50&t=1201
sandord
Post by sandord »
exxos wrote: Fri Sep 28, 2018 5:03 pm Very strange.
Sadly, no.
I found this program, never used it, but looks like it does some bit tests on screen...
MEMTEST.zip
(1.22 KiB) Downloaded 167 times
