Well my point is to not enabling one or the other, but both. I.e, with a compatible screen you should just be able to display a color or mono mode just like switching between any other resolutions. No manual switch needed.exxos wrote: 24 Sep 2018 17:15 Mux are easy enough. Really just 2 buffers in parallel, just enable one or the other set of buffers. RGB on one set of inputs, MONO on all RGB inputs on the second buffer. I think its basically what the UBE does.
(An automatic switch could be done by listening on ff8260/1, if that's really easier)
