Icky - Progress
Re: Icky - Progress
exxos wrote: Tue Nov 27, 2018 1:39 pm
Icky wrote: Tue Nov 27, 2018 1:37 pm I think Exxos won't be happy until my PSU is standing at least a foot above the board.
:lolbig: :bravo:
Probably best I don't start on the 1772 AB swap GAL thing just yet then :P
Don't worry, there's plenty of other chips left to unf*ck yet :D
PaulJ
Re: Icky - Progress
Post by PaulJ »
Forgottenmyname wrote: Tue Nov 27, 2018 1:43 pm
:lolbig: :bravo:
When this all gets incorporated into the new board we should call it the UN-Fu*ker!!
PaulJ
Re: Icky - Progress
Post by PaulJ »
:lolbig: :bravo:
We should do something grand for the penthouse un-fu*kit board... something that towers over Icky's power supply with lots of connectors on it. :mrgreen: :mrgreen: :mrgreen:
Re: Icky - Progress
Icky wrote: Tue Nov 27, 2018 1:37 pm Its getting very tight in there. Video DAC board is intruding on the PSU mounts shifting it back a bit.
Wonder if my floppy standoffs would work for the PSU?
Re: Icky - Progress
rubber_jonnie wrote: Tue Nov 27, 2018 2:15 pm
Might need quite a few of them by the time Exxos is finished. :D
Due to the board not having the right hole locations I had to improvise with L legs using nylon stand-offs. Super glue works wonders sticking those things together.
So some how your floppy standoffs would need to be L shaped.
Re: Icky - Progress
Icky wrote: Tue Nov 27, 2018 2:37 pm
Would be quite easy to do, what's the difference between centres?
Re: Icky - Progress
rubber_jonnie wrote: Tue Nov 27, 2018 3:30 pm
I'll have a look as they could be a bit more offset than I have them.
Re: Icky - Progress
Roger that 😁
Re: Icky - Progress
rubber_jonnie wrote: Tue Nov 27, 2018 6:20 pm Roger that 😁
Finally got the PSU into a position that all the layers of boards, shelves, extensions etc were ok.
I’ll send out dimensions tonight for the legs. Currently the nylon spacers superglued together are holding but they are not that stable. One looks like a honeycomb monstrosity. :)
Re: Icky - Progress
Cool, I'll see what I can come up with, as I will need some anyway.
Return to “ALPHA USER BUILDS”
