Icky - Progress
Re: Icky - Progress
exxos wrote: Mon Oct 08, 2018 11:38 am Is there a typo on pin 5, as on the ST sch pin 5 is drive_0..
Yes a typo in my diagram pin 5 should be drive 0 - I did create it in the early hours - thought I had found all the bugs.
I guess I'm not so good with connectors either :)
Re: Icky - Progress
Correcting -
Screen Shot 2018-10-08 at 13.21.15.png (232.12 KiB) Viewed 3952 times
Re: Icky - Progress
Icky wrote: Mon Oct 08, 2018 1:21 pm I guess I'm not so good with connectors either :)
12 pins better than me though ;)
Started a new thread for this board...
https://www.exxosforum.co.uk/forum/viewt ... =19&t=1248
https://www.exxosforum.co.uk/atari/ All my hardware guides - mods - games - STOS
https://www.exxosforum.co.uk/atari/store2/ - All my hardware mods for sale - Please help support by making a purchase.
viewtopic.php?f=17&t=1585 Have you done the Mandatory Fixes ?
Just because a lot of people agree on something, doesn't make it a fact. ~exxos ~
People should find solutions to problems, not find problems with solutions.
Re: Icky - Progress
Just looking through the DMA pdf...
It only seems to say is driven with a open collector, but does not really say is needed for any reason..
Re: Icky - Progress
exxos wrote: Mon Oct 08, 2018 10:03 pm Just looking through the DMA pdf...
I was just scoping the RDY line on the DMA and noticed the undershoot like in your BAD DMA MYTH http://www.exxosforum.co.uk/atari/last/DMAfix/.
Re: Icky - Progress
Icky wrote: Mon Oct 08, 2018 10:23 pm I was just scoping the RDY line on the DMA and noticed the undershoot like in your BAD DMA MYTH http://www.exxosforum.co.uk/atari/last/DMAfix/.
It can also be where you have grounded the scope.. assuming you are on a gnd point very close to the DMA..
Also try on x10 probe... Sometimes a probe itself can appear to give you things which are not actually there...
It is also worth probing every pin of the DMA to see if anything looks odd... The address and databus to the DMA will likely look like chaos anyway..
Re: Icky - Progress
exxos wrote: Mon Oct 08, 2018 10:26 pm
Probe is on 10x and ground point I am currently using is the DMA socket shield lugs. Will move it closer and look at the other lines.
Re: Icky - Progress
Icky wrote: Mon Oct 08, 2018 10:31 pm
So far nothing looks out of place. Have even tried different ACSI cables and drives.
Odd though as I did get the device recognised once but not since - must of been a fluke or all the stars aligned
Re: Icky - Progress
Icky wrote: Mon Oct 08, 2018 11:38 pm Odd though as I did get the device recognised once but not since - must of been a fluke or all the stars aligned
Have you tried with and without the RP900 in place ?
Other than that TTL chip there isn't much else to check... for the hell of it, if you have a 001 DMA :lol:
It could be possible noise on the DMA port itself on a dataline ?
Re: Icky - Progress
exxos wrote: Mon Oct 08, 2018 11:51 pm Have you tried with and without the RP900 in place ?
Just did - no difference still doesn't see floppy when hdd is connected
exxos wrote: Mon Oct 08, 2018 11:51 pm Other than that TTL chip there isn't much else to check... for the hell of it, if you have a 001 DMA :lol:
Nope don't have a -001 DMA just -38's
Return to “ALPHA USER BUILDS”
