What may confuse about DRQ on the DMA having a pull up on the original (the 1K is on the input).. Is the output doesn't have pull up, BUT, that is because original ST used open collector to the DMA pin (LS06).. I used a LS04 which doesn't need pull up. This buffer only drives DMA input, so I saw no problem with that...But maybe something doesn't like that, as even on STE uses LS06... odd...
Might be worth checking I wired the DMA port up right though
