I've been following the whole board development in general and this thread in particular pretty much since the start; impressive work all around.
I am burning with one question; could test some demo footage with fullscreen/spectrum 512; Im REALLY interested to see how much of a perfect compatibility this new board would give!
Kind regards,
Wietze
Icky - Progress
Re: Icky - Progress
As it's using all the original chips, just replacing the integration between them, there will be no difference.wietze wrote: 07 Oct 2018 17:29 I've been following the whole board development in general and this thread in particular pretty much since the start; impressive work all around.
Kind regards,
Wietze
Re: Icky - Progress
I can confirm it behaves as per original STFM during demos. As Stephen mentions the machine is a modern integration with original chips.stephen_usher wrote: 07 Oct 2018 17:48 As it's using all the original chips, just replacing the integration between them, there will be no difference.
Re: Icky - Progress
Tried this patch on the board with no change. Still not seeing floppy drives when HDD plugged inIcky wrote: 07 Oct 2018 09:59I'll give that patch a go to see if it fixes the problem. Need to test Megafile on STFM though first to make sure it is behaving correctlyexxos wrote: 07 Oct 2018 09:54 I've actually had the problem recently with when hard drives were connected the floppy drive would stop working.. was a bugger to find..but...
https://www.exxosforum.co.uk/forum/viewt ... 015&p=7620
Re: Icky - Progress
Bummer, so will have to diagnose that one when my board comes then.Icky wrote: 07 Oct 2018 19:24 Tried this patch on the board with no change. Still not seeing floppy drives when HDD plugged in
Re: Icky - Progress
Got a email saying its almost done.. hopefully tomorrow...
rpineau
Re: Icky - Progress
Can you guys check the pull-up on /DRQ , just in case ;)
Pin 1 of U51 -> pull-up -> 5v
I also check the STE and MSTE schematic and the DMA port is fully buffered there as opposed to the STFM. Might be something to add on the next rev.
Also the INT pins from the DMA and FDC are going through some 74LS02 to be combined into one int signal to the MFP instead of being hard wired together on the STFM .. could help make things more stable (in the future).
Re: Icky - Progress
Pull up is in RP1.
Re: Icky - Progress
Yep - just measured 1K
Users browsing this forum: CCBot and 52 guests
