Icky - Progress
Re: Icky - Progress
Icky wrote: Fri Oct 05, 2018 4:35 pm
exxos wrote: Fri Oct 05, 2018 3:50 pm Thanks. So will add some buffers on the next revision board. It should probably work with another 75R in series with the diode ?
I'll give that a try.
To be clear when you say it will probably work with another 75R in series is that with or without the capacitor?
Re: Icky - Progress
Icky wrote: Fri Oct 05, 2018 5:17 pm To be clear when you say it will probably work with another 75R in series is that with or without the capacitor?
I mean with the capacitor and diode. I was just thinking of limiting the charge current to the capacitor a little. Even 33R will help take the edge of. Though depends what your TV is happy with how the voltage ends up.
Re: Icky - Progress
exxos wrote: Fri Oct 05, 2018 5:18 pm
Thanks
Re: Icky - Progress
Icky wrote: Fri Oct 05, 2018 5:24 pm
Thanks
Ended up going down to a 47R. With 75R the flicker and bounce came back.
Re: Icky - Progress
Icky wrote: Fri Oct 05, 2018 7:02 pm Ended up going down to a 47R. With 75R the flicker and bounce came back.
Cool! So worth noting 33R is probably a good value to go with ultimately.
Re: Icky - Progress
exxos wrote: Fri Oct 05, 2018 7:06 pm
Indeed - so that is one item knocked off my list. Cable sorted and flicker gone. However there is that noise as we have discussed. Won't be able to scope till tomorrow, non-atari duties are calling.
Re: Icky - Progress
Icky wrote: Fri Oct 05, 2018 7:21 pm Indeed - so that is one item knocked off my list. Cable sorted and flicker gone. However there is that noise as we have discussed. Won't be able to scope till tomorrow, non-atari duties are calling.
Be interesting to find out where the noise is coming from. My money is on the RGB drivers and the caps. There could be some glitches on the shifter output causing it and the caps "cover up" the problem on the design.
There are some video buffers I got for the Svideo 2600 stuff which included some filtering internally for noise.. so may look at those again.. might do for a simple replacement driver.
Re: Icky - Progress
I have been tracing the external floppy connector and unfortunately I think its wired wrong - could do with someone else checking.
I have been checking the pinouts with an original ST as well.
This is what I have found - the diagram on the right is how the STF Remake is wired to the socket and the one on the left is how it should be - I could stand corrected though.
Screen Shot 2018-10-06 at 01.29.06.png (229.51 KiB) Viewed 4209 times
Re: Icky - Progress
Icky wrote: Sat Oct 06, 2018 12:58 am I have been tracing the external floppy connector and unfortunately I think its wired wrong - could do with someone else checking.
Gone over it again - only one slight correction is on the actual image pin 7 should be GND
Screen Shot 2018-10-06 at 08.40.28.png (228.75 KiB) Viewed 4181 times
i used this pinout to help from https://info-coach.fr/atari/hardware/interfaces.php
Screen Shot 2018-10-06 at 01.03.52.png (105.56 KiB) Viewed 4181 times
DoG
Re: Icky - Progress
Post by DoG »
Should just point that out. You beat me to it. Great work otherwise!
Return to “ALPHA USER BUILDS”
