Icky - Progress
Re: Icky - Progress
reading the wd1772 datasheet it says that 20 is used to enable the spindle. This is staying high when it gets to desktop.
Do you know what /CS should be doing? it pulses low once on 80ns scale
Re: Icky - Progress
I don't know what timings anything has really.. you would have to check on a working ST and compare them all.
The ST does poll the drive like twice a second or something.. so likely CS goes low during those times.
TheNameOfTheGame
Re: Icky - Progress
Post by TheNameOfTheGame »
Maybe my memory is foggy, but I always thought the drive would be damaged by plugging the cable in upside down. Something about voltages on the wrong pins that way. :?:
Re: Icky - Progress
exxos wrote: Thu Sep 27, 2018 4:23 pm
exxos wrote: Thu Sep 27, 2018 10:24 am It might be worth scoping out some pins around ACIA area, such as (U54) A1 pin 11, A2 pin 8, (U32) pin 3 SNDCS.. (IC2 MFP) pin 48 CS.
Back to the plot...
Wow I go off grid for a day and see what happens. Great discussion on floppy controllers and drives though.
I’ll take a look at scoping out the signals later tonight.
Re: Icky - Progress
TheNameOfTheGame wrote: Thu Sep 27, 2018 7:13 pm Maybe my memory is foggy, but I always thought the drive would be damaged by plugging the cable in upside down. Something about voltages on the wrong pins that way. :?:
I have stuck drive cables in the wrong way many a time on an ST. I haven’t had one damaged but I could just be lucky.
Re: Icky - Progress
Same for me and usually the drive light staying on is a key to it being the wrong way round (on a pc at least!)
Re: Icky - Progress
Forgottenmyname wrote: Thu Sep 27, 2018 7:18 pm Same for me and usually the drive light staying on is a key to it being the wrong way round (on a pc at least!)
Funny was about to say that’s my rule of thumb :)
Re: Icky - Progress
Well joystick port works - have been playing Xenon II :)
Re: Icky - Progress
In order on the scope as per your pins above:
(U54) A1 pin 11 - CH1, A2 pin 8 - CH2, (U32) pin 3 SNDCS - CH3, (IC2 MFP) pin 48 CS - CH4
Re: Icky - Progress
Ah, you need to be on 5v/div on each... Also hold down a key to trigger sounds and acia...
Return to “ALPHA USER BUILDS”
