I have some bad news on the audio since the dateline re-wire on the ACIAs the sound has gone away. Forgottenmyname also is has no audio.exxos wrote: Wed Sep 26, 2018 10:42 pm Might be a idea to scope out the RDY line.. I've had a lot of trouble with that on the STE..
I took a quick look at the audio amp, its actually got more gain than the original ST amp![]()
Icky - Progress
Re: Icky - Progress
Re: Icky - Progress
Floppy..
I'm not really liking no pullups on the LS06... you could try something like 10K pull ups on U14's outputs...
Re: Icky - Progress
OK - That something I can tryexxos wrote: Wed Sep 26, 2018 10:51 pm Floppy..
Re: Icky - Progress
Must be some other issues somewhere then, as ACIA has nothing to do with audio..Icky wrote: Wed Sep 26, 2018 10:49 pm I have some bad news on the audio since the dateline re-wire on the ACIAs the sound has gone away. Forgottenmyname also is has no audio.
Re: Icky - Progress
Can't see any issues with the floppy circuit.. I guess someone needs to double check I haven't missed anything..
Did you try formatting a floppy ?
Re: Icky - Progress
For the audio, as said before, try audio test in the cart, scope out the YM outputs and see if you get anything there during the audio test...
Re: Icky - Progress
So its pull-ups againexxos wrote: Wed Sep 26, 2018 10:51 pm Floppy..
Those pull-ups on the U14 sprang the floppy into life.
So now we have...........
GEMBench for STF remake - well done Exxos you have done it
Re: Icky - Progress
oh wow...Icky wrote: Wed Sep 26, 2018 11:27 pm So its pull-ups again
I wonder if thats a long term ST issue then with those pull ups because they are not on any of the diagrams , not even falcon...
Re: Icky - Progress
I am surprised you don't dream pull-ups in your sleep Exxosexxos wrote: Wed Sep 26, 2018 11:29 pm I wonder if thats a long term ST issue then with those pull ups because they are not on any of the diagrams , not even falcon...
Re: Icky - Progress
Sleep ? Strange words.... I normally dream of the world ending in one way or another.. normally zombies
