Icky - Progress
Re: Icky - Progress
exxos wrote: Tue Sep 25, 2018 10:26 pm :lol: Missing resistor on the keyboard ... man, what is it with me and pull up resistors :lol: :roll:
:) - Looks like you are pull-up resistor blind.
Re: Icky - Progress
Icky wrote: Tue Sep 25, 2018 10:33 pm :) - Looks like you are pull-up resistor blind.
Must be, reverse of OCD I guess...
Re: Icky - Progress
exxos wrote: Tue Sep 25, 2018 10:34 pm
So looks like the keyboard fix pull-up has actually fixed the sound.
Also in doing the diagnostic cart the DMA Port Test comes back with:
DMA Port Test
D0 DMA time-out
Fail at cycle:000001
Re: Icky - Progress
I think you need a special cable for DMA test...
Best thing is to put a blank floppy in the drive and try the floppy tests (it formats a floppy somewhere)
troed
Re: Icky - Progress
Post by troed »
Icky wrote: Tue Sep 25, 2018 10:59 pm Also in doing the diagnostic cart the DMA Port Test comes back with:
DMA Port Test
D0 DMA time-out
Well many of those tests require a test harness connected to the ports that route signals back.
Re: Icky - Progress
OK so 2 images posted for the ACIA BUS FIX... hopefully that will be the last one... nothing like ending on the worst fix! :lol:
Re: Icky - Progress
exxos wrote: Tue Sep 25, 2018 11:28 pm OK so 2 images posted for the ACIA BUS FIX... hopefully that will be the last one... nothing like ending on the worst fix! :lol:
DONE - And we have keyboard and mouse. Video shows changing to medium res but the floppy is not accessing the drive correctly
Exxos - I doff my cap to you for all your hard work
Re: Icky - Progress
Yay!
Might be worth unsoldering the resistor pack next to the 1772 ( should be 10k).. And see if that helps.
Also swap the tos jumper as looks like your running 102 there..
Re: Icky - Progress
exxos wrote: Wed Sep 26, 2018 3:24 am Yay!
Jumper swapped and working with other TOS
Pulled out resistor pack as I SILed them. Still no joy. Its accessing the drive but not seeing it properly.
mikro
Re: Icky - Progress
Post by mikro »
Icky wrote: Wed Sep 26, 2018 12:23 amDONE - And we have keyboard and mouse. Video shows changing to medium res but the floppy is not accessing the drive correctly
:o Unbelievable. Hats off guys, you made it working in like what, two weeks? Amazing.
I guess the video also shows the screen flashing? Or is it just an artefact by recording?
Return to “ALPHA USER BUILDS”
