This is what I ended up with. My USB to Serial has a male 25 pin and the STF has a male 25 pin. Therefore I wired two female 25 pin sockets together like this - hope this helps:Forgottenmyname wrote: Sun Sep 23, 2018 7:32 pm Please could you show me the pinout you used?
It might be incompatible with my FTDI guess, so can try a usb-serial later on.
Icky - Progress
Re: Icky - Progress
Re: Icky - Progress
Ok, thanks Icky, I only connected Rx,TX and Gnd, will try the rest too but with a not so bodged cable.
Re: Icky - Progress
Thanks rpineaurpineau wrote: Sun Sep 23, 2018 7:15 pm so I6 (IPL 6) is the MFP. "No (I6) error" ..looks like MFP interrupt handler are ok.
One more step closer
With serial working, all we now need is the DiagROM which should arrive from Exxos tomorrow - fingers crossed.
Re: Icky - Progress
So, as suspected, a NULL modem cable.
Re: Icky - Progress
Indeed - one and the same
Re: Icky - Progress
I6 is simply the 6th test during initialization. It has nothing to do with IPL6 or the MFP interrupts! In fact, this step simply tests that a write to $0 causes a bus error. After that, the diagnostic cartridge will enable interrupts and will go on printing "Testing MFP, Glue timing, Video". When it shows "E7 Spurious interrupt" instead, this means that an interrupt was signaled to the CPU but no device responded to the interrupt acknowledge. I suppose this could happen when at least on the IPL lines to the CPU is stuck low.rpineau wrote: Sun Sep 23, 2018 7:15 pm so I6 (IPL 6) is the MFP. "No (I6) error" ..looks like MFP interrupt handler are ok.
Re: Icky - Progress
Ok, my mistake
Re: Icky - Progress
Spurious Interrupt either means something on the bus is corrupting the data on the bus and running the wrong interrupt (my thoughts for the ACIA as I have had that issue with my boosters), or the interrupt vector hasn't been set in RAM. I don't know much about how all that stuff works though. I think the fault was autovector issues, but can't remember if the cart said auto vector or not. I did know more about this stuff while doing the SEC code, but mostly forgot how it all works now
I6 should never get triggered. With my SEC booster, the ACIA cycles were causing issues corrupting the bus and ended in I6 errors. So for some reason we are running I6 when we shouldn't be.. The corrupt data on screen hints to corruption somewhere..
We ruled out the ACIA conflicts at least. It shard to know where or what to look for, though could be something relating to the MFP circuit.
Exception Vectors
$000 Initial SSP value after reset
$004 Initial PC address after reset
$008 Bus error vector
$00C Address error vector
$010 Illegal instruction vector
$014 Divide by zero vector
$018 Check instruction vector
$01C Trapv instruction vector
$020 Privilege violation vector
$024 Trace vector
$028 Line 0101
$02C Line 1111
---- Reserved ($30-$5F)
$060 Spurious interrupt (level 6)
$064 Interrupt level 1 (HBL)
$068 Interrupt level 2 (HBL)
$06C Interrupt level 3 (processor interrupt)
$070 Interrupt level 4 (VBL)
$074 Interrupt level 5
$078 Interrupt level 6 (MFP interrupts)
$07C Interrupt level 7 (non-maskable interrupt)Re: Icky - Progress
I took your suggestions and started looking at the MFP on an original STFM. I noticed a few pull-ups missing especially the IRQ pin 32 on the MFP.exxos wrote: Sun Sep 23, 2018 10:08 pm We ruled out the ACIA conflicts at least. It shard to know where or what to look for, though could be something relating to the MFP circuit.
Exception Vectors $060 Spurious interrupt (level 6) $078 Interrupt level 6 (MFP interrupts)
I did that pull-up with a 1K as I wanted to see if this was part of the problem and .......
We have a green desktop - although still with the glitches
Re: Icky - Progress
I will check the pull ups tomorrow again. I didn't see I missed any but obviously you are on the right track there!
I don't get the odd graphics problems though. Its like the shifter is getting bad data for some reason. It must be pretty good on ram access to even get to the desktop though..odd.
