Icky - Progress
Re: Icky - Progress
exxos wrote: Fri Sep 21, 2018 10:04 am
Icky wrote: Fri Sep 21, 2018 9:55 am That is my next item. I have a spare rom chip from your store already. Thought I would reprogram with DiagROM - any pointers?
Yeah, you can't reprogram the ROM's from my store :P
Darn :-( that would of been too easy. Should of thought ROM not PROM :oops:
In that case could you post me a chip?
Re: Icky - Progress
Icky wrote: Fri Sep 21, 2018 10:08 am In that case could you post me a chip?
Will do, probably won't be until tomorrow though :(
Re: Icky - Progress
exxos wrote: Fri Sep 21, 2018 10:12 am Will do, probably won't be until tomorrow though :(
Thanks - no rush. Gives me time to find that USB to Serial Cable and build the adaptor to the STF board
Re: Icky - Progress
Icky wrote: Fri Sep 21, 2018 10:25 am Thanks - no rush. Gives me time to find that USB to Serial Cable and build the adaptor to the STF board
Do you have a diagnostic cart ? might be worth trying just for the hell of it.
Re: Icky - Progress
exxos wrote: Fri Sep 21, 2018 10:26 am Do you have a diagnostic cart ? might be worth trying just for the hell of it.
I do - it just arrived in the post 5 minutes ago.
Plugged it in and what do I get:
E7 Spurious Interrupt
troed
Re: Icky - Progress
Post by troed »
Text output on screen or over serial?
Re: Icky - Progress
troed wrote: Fri Sep 21, 2018 10:41 am Text output on screen or over serial?
Re: Icky - Progress
Icky wrote: Fri Sep 21, 2018 10:38 am E7 Spurious Interrupt
I have had that while doing booster work... Will try and find what it was, I think it was some issues while I was doing the ACIA code for the SEC booster...
BlankVector
Re: Icky - Progress
Post by BlankVector »
Icky wrote: Fri Sep 21, 2018 12:39 am Here it is we have proper video :yay2:
Great job :D
BTW, that picture is really strange. The bombs are perfectly clean and stable, which means that the Shifter works well. But I can' figure where the strange background could come from...
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a monochrome pixel in assembly language on Atari ST.
Re: Icky - Progress
BlankVector wrote: Fri Sep 21, 2018 10:48 am
Great job :D
Yes it is strange but actually quite pretty
Return to “ALPHA USER BUILDS”
