Forgottenmyname - Progress
Re: Forgottenmyname - Progress
So far today, replaced CPU socket and found a broken bodge wire that was ocasionally making contact, hence confusing the hell out of me.
So now I can properly concentrate on finding why my floppy doesn't work
Edit 1
Ok, so now the STF boots to TOS, sees the floppy but won't read or format it. I get 4 bombs generally when trying to boot to a floppy.
When I boot up the diag rom it passes ram, etc. It will do track seeks and speed tests on the floppy but not format it. I get error E9 when I try to format.
So now a couple of steps forward, which is cool.
Forgottenmyname wrote: Fri Nov 30, 2018 3:40 pm So now I can properly concentrate on finding why my floppy doesn't work!
Hope you have some luck soon!
exxos wrote: Fri Nov 30, 2018 3:53 pm
thanks, getting there slowly. may just replace a couple more sockets, ie DMA and Shifter to rule them out too
Well, that was an interesting and probably the end of my STF project, at least part one anyway.
Last night had a power cut whilst I was playing with the STF, scope, etc. Powered it back up and no display, burning smell, etc....
I don't think it's the PSU as that's outputting all the right voltages but now my STF is dead.... hopefully not permanently.
Guess the luck exxos wished me back fired, LOL.
Still, I shall look on as you guys work on your STF's and will wait patiently for Part two / mongrel board.
Now off to see why one of my Mega's doesn't work properly too after last night.
PaulJ
Post by PaulJ »
Forgottenmyname, sorry to hear of your machines passing.. :sorry:
Oh no, can you test the chips in another st ?
PaulJ
Post by PaulJ »
I hope you had a doner card filled out! :signhere:
LOL, yes I did have a donor card filled out.
I'll pop the chips one by one in another ST and see what happens. Hopefully its something daft like a transistor on the RGB circuit, as there's no output but the shifter is generating 16mhz etc still.
That is bad luck. Are you trying to out do me on the PSU failures / issues? I think I racked up 3 last month. Biggest one being my PC PSU which just went dead overnight. Not a small unit either Corsair RM850.
Lets hope you can salvage something out of the board i.e. its an easy fix.
And the not so amusing thing is that my "best" Mega 4 now has the same issue that the STF had, it won't read from floppy without 4 bombs.
Return to “ALPHA USER BUILDS”
