Forgottenmyname - Progress
Re: Forgottenmyname - Progress
Soldering bodge no.2, I have no idea how I missed that, dunno where the pins gone either! :shock:
And it works!
No sound yet but that might simply be a cable fault?
Will work on that next.
Forgottenmyname wrote: Sun Sep 30, 2018 9:21 pm And it works!
:cheer:
It was a case of the missing pin.
Yes, no need to call in Mr Inspector Exxos anymore :D
:bravo:
Seems sound is common fault. As said before, need to do sound test on diag-cart and check out the YM chip outputs for starters...
Actually, sound is soldering bodge no.3, if I'd only connected it to the right pin on the plug :D
Forgottenmyname wrote: Sun Sep 30, 2018 9:39 pm Actually, sound is soldering bodge no.3, if I'd only connected it to the right pin on the plug :D
So you have sound then ?
:) - Snap
Just need to figure out the video on an LCD monitor. Am moving more stuff to get the STF plugged into another monitor.
Yeah, although now i have a dodgy keyboard, LOL
I think the keyboard has now died
So you guys both have sound working now then ?
Return to “ALPHA USER BUILDS”
