It does work on the ST as I tried it out myself...
As for diagnostic carts, still WIP.. waiting for china to open up so I can order my new PCB's...
DiagROM for ST
PaulJ
Re: DiagROM for ST
Hmm, makes me think I'm getting soft in the melon..Tried it in 2 mega's and a ST. All three booting no issue 1.04. Run the atari DiagROM cart first to insure I have no issues with serial...?
I don't need to hold down a key or something?
Re: DiagROM for ST
hmmm, I've not tried the cart version yet I think... You may be better replacing the OS ROM's with Diagrom, its how I did it.PaulJ wrote: 10 Feb 2019 22:09 Hmm, makes me think I'm getting soft in the melon..Tried it in 2 mega's and a ST. All three booting no issue 1.04. Run the atari DiagROM cart first to insure I have no issues with serial...?
- Admin sponsor
Re: DiagROM for ST
No key is needed to boot DiagROM from a cart.
PaulJ
Re: DiagROM for ST
Not using a cart, using it as the boot rom. Took out the tos rom and put in DiagROM, applied power gray screen, no serial.. same all computers.
Re: DiagROM for ST
Maybe your programmer is byte swapping the ROMs ?PaulJ wrote: 10 Feb 2019 22:34 Not using a cart, using it as the boot rom. Took out the tos rom and put in DiagROM, applied power gray screen, no serial.. same all computers.
- Admin sponsor
Re: DiagROM for ST
STE? or ST?
Anyways I have tested the 256K version in a real machine. I havent tested the 192K version in a real machine. So you might need to resplit the roms.
PaulJ
Re: DiagROM for ST
Checked the burn in the 16 bit eprom and all the text is readable so its not byte reversed.. This has to be something stupid!!
Re: DiagROM for ST
Post the file here and I will byteswap it for you if needs be.PaulJ wrote: 10 Feb 2019 22:56 Checked the burn in the 16 bit eprom and all the text is readable so its not byte reversed.. This has to be something stupid!!
PaulJ
Re: DiagROM for ST
Heres the beginning and end of the file. I am burning it into a 27C4096 16 bit eprom. Looks fine to me. Compared it to a TOS 1.04 image and in both the text is readable. I didn't see any way to upload a binary.. :) :)
