DiagROM for ST
DiagROM software & help
czietz
Re: DiagROM for ST
Post by czietz »
terriblefire wrote: Tue Sep 18, 2018 11:26 am You won’t get to the menu with broken ram. You should get that on the early serial port. Did you check that?
I didn't see that because the screen of the serial terminal was filled within seconds with a seemingly endless stream of crash dumps. Now that I have enabled logging into a file, I can indeed see that memory errors show up as "FAILED":
Atari DiagROM V0.9 - 16-Sep-18
 - By Stephen J. Leary
 - Based on the Amiga Version By John (Chucky/The Gang) Hertell
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
 - Resetting all hardware (RESET instruction): Done.
 - Reinitialising Video ($10000): Done.
 - Sending reset to keyboard controller (IKBD Reset): Done.
- Parallel Code $fe - Test UDS/LDS line
 - Test of writing word $FFFF to $400 OK.
 - Test of writing word $00FF to $400 OK.
 - Test of writing word $FF00 to $400 OK.
 - Test of writing word $0000 to $400 OK.
 - Test of writing byte (even) $ff to $400 OK.
 - Test of writing byte (odd) $ff to $401 OK.
- Parallel Code $fd - Start of chipmemdetection
  - Performing MMU Configuration: $02 Done.
Addr $00000400Write:AAAAAAAARead:A2AAA2AA   FAILED
Addr $00000400
Addr $00000400
Addr $00000400Write:0F0F0F0FRead:070F070F   FAILED
Addr $00000400
Addr $00008400Write:AAAAAAAARead:A2AAA2AA   FAILED
Addr $00008400
Addr $00008400
Addr $00008400Write:0F0F0F0FRead:070F070F   FAILED
Addr $00008400
Addr $00010400Write:AAAAAAAARead:A2AAA2AA   FAILED
Addr $00010400
Addr $00010400
Addr $00010400Write:0F0F0F0FRead:070F070F   FAILED
Addr $00010400
Addr $00018400Write:AAAAAAAARead:A2AAA2AA   FAILED
Addr $00018400
Addr $00018400
Addr $00018400Write:0F0F0F0FRead:070F070F   FAILED
Addr $00018400
Addr $00020400
Addr $00020400
Addr $00020400
Addr $00020400
Addr $00020400   OK  Number of 32K blocks found: $01
Addr $00028400
Addr $00028400
Addr $00028400
Addr $00028400
Addr $00028400   OK  Number of 32K blocks found: $02
Addr $00030400
Addr $00030400
Addr $00030400
Addr $00030400
Addr $00030400   OK  Number of 32K blocks found: $03
Addr $00038400
Addr $00038400
Addr $00038400
Addr $00038400
Addr $00038400   OK  Number of 32K blocks found: $04
Addr $00040400
Addr $00040400
Addr $00040400
Addr $00040400
Addr $00040400
Startaddr: $00020400 Endaddr: $00040000
- Parallel Code $fb - Memorydetection done
- Parallel Code $fc - Start of motherboard fastmemdetection
Detecting if we have a working raster: DETECTED
Detected Chipmem: 128KB
Detected Motherboard Fastmem: 1104KB
Basememory address: $0002CE32
- Parallel Code $f9 - Detected memory in use, we now have a stack etc
Done
- Parallel Code $f8 - Starting up screen, text echoed to serialport
To use serial communication please hold down ANY key now
OR hold down the RIGHT mousebutton on the Amiga during poweron
Holding down the LEFT mousebutton will force serial on and turn off screen
forcing stuff to run in fastmem if avaible
                          Illegal Instruction DetectedDebugdata (Dump of CPU Registers D0-D7/A0-A7):$00002700 $00000001 $00002676 $000203E4 $00000004 $000001FF $000000FF $000004A3
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002ED22
                          Illegal Instruction DetectedDebugdata (Dump of CPU Registers D0-D7/A0-A7):$00002210 $00000001 $00002676 $000203E4 $00000004 $000001FF $000000FF $00000013
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002EC0E
                          Illegal Instruction DetectedDebugdata (Dump of CPU Registers D0-D7/A0-A7):$00002210 $00000001 $00002676 $000203E4 $00000004 $000001FF $000000FF $00000015
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002EAFA
                          Illegal Instruction DetectedDebugdata (Dump of CPU Registers D0-D7/A0-A7):$00002210 $00000001 $00002676 $000203E4 $00000004 $000001FF $000000FF $0000000C
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002E9E6
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002E8D2
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002E7BE
$00E0A8BC $0002EE42 $00C80000 $00E022F6 $00E012CE $0003F804 $0002EE36 $0002E6AA
This "Illegal Instruction Detected" debug data dump continues for a while.
Maybe the program could wait for key press when memory errors are found so that the user can actually read the serial output?
terriblefire wrote: Tue Sep 18, 2018 11:26 am Either way this forum is not how you report bugs. (Because I only check the forum when Exxos pings me an mail to look at something)
Sorry, this wasn't clear to me. Perhaps you should add your preferred way of getting bug reports to the initial posting.
Re: DiagROM for ST
I’ll take a look at the illegal instructions. Mostly this was created for me to get my accelerators Woking on the ST but people persuaded me to release it. I didn’t design DiagROM though but I am familiar with it.
Re: DiagROM for ST
Btw I use putty for this so I just scroll up to see the history.
Re: DiagROM for ST
Maybe if its not detecting RAM amount correctly that is why its going a bit wonky if run on a 4MB machine ? I think your machine was stuck in 512K so could be why you are not seeing those issues ?
Re: DiagROM for ST
Hi TF, just a quick question, as is, will this boot from a cartridge on the STF? or will it need to be in the ROM socket?
I can burn some DIP proms which will fit the carts.
Re: DiagROM for ST
Forgottenmyname wrote: Tue Sep 18, 2018 2:58 pm Hi TF, just a quick question, as is, will this boot from a cartridge on the STF? or will it need to be in the ROM socket?
See his repo...
https://github.com/terriblefire/diagrom ... master/bin
Re: DiagROM for ST
exxos wrote: Tue Sep 18, 2018 3:01 pm
See his repo...
Yeah I saw that but wasn't sure if it would still boot before TOS or not?
Re: DiagROM for ST
It will work as a cart but that needs at least a working ROM to execute the first 10 instructions or so.
I am considering also echoing the console out to midi... would that be annoying or useful?
Re: DiagROM for ST
terriblefire wrote: Wed Sep 19, 2018 8:37 pm It will work as a cart but that needs at least a working ROM to execute the first 10 instructions or so.
IMHO probably not worth going down that road.. at least not yet..
terriblefire wrote: Wed Sep 19, 2018 8:37 pm I am considering also echoing the console out to midi... would that be annoying or useful?
If it can be as well as serial then it can only help... the rs2s2 is a new circuit, and not tested, other chips may not be working either , so ACIA output stands a better chance of working right currently.
Re: DiagROM for ST
OK i just pushed an update that echo's to MIDI. I've not got midi in working yet so you need a keyboard or serial port to control it.
Return to “DiagROM”
