DiagROM for ST
DiagROM software & help
Re: DiagROM for ST
Well done for finding the problem :dualthumbup:
PaulJ
Re: DiagROM for ST
Post by PaulJ »
Ya know I've been doing this for 30 years and I've never seen an eprom get the thumbs up after programing and not work in the target hardware. Maybe an issue in the socket? Oh well one should never work with only one eprom.
Re: DiagROM for ST
PaulJ wrote: Tue Feb 12, 2019 3:10 pm Ya know I've been doing this for 30 years and I've never seen an eprom get the thumbs up after programing and not work in the target hardware. Maybe an issue in the socket? Oh well one should never work with only one eprom.
Some ROMs don't even work in the ST. Texas ROMs for some reason have always been troublesome. Where are used to work use to have to program thousands of ROM's every year. It actually took as a while to work out some's were failing even though they are the same software updates.. Long story short, every machine which had a Texas ROM failed. We never really looked into it, or found out why, there was the same as SGS ROM's etc. Though I have noticed this on the STE as well. So simply burning a set of ROM's and having them verified, does not guarantee they will actually work in the target hardware.
Also if you are using CRC check, although unlikely, it does not actually guarantee contents are burned correctly.
Re: DiagROM for ST
Hmmm, been using Texas roms on the Pak, wondering that's why the Tos didn't load.
PaulJ
Re: DiagROM for ST
Post by PaulJ »
Try another one just to make sure.. :D
Re: DiagROM for ST
PaulJ wrote: Tue Feb 12, 2019 4:57 pm Try another one just to make sure.. :D
I best go buy another 4 then as all my 27c010s are TI.
PaulJ
Re: DiagROM for ST
Post by PaulJ »
Not that China is the issue but I ordered new ones from mouser. Its just happens that every time I get bitten by something wierd it comes from China.
Re: DiagROM for ST
Post by JezC »
I've a couple of STFMs which don't boot to the desktop & thought that DiagROM might be a good way to try & see what needed doing.
I don't currently have any option but to fit the ROMs in place of the current TOS ROMs.
The boards have 2 ROMs fitted, TOS 1.02.
I have some 27c256 EPROMs (6x 250ns, 2x 150ns) plus a pair of 27c512s kindly supplied by RJ & was wondering if there is a build of DiagROM which will fit into these to diagnose the issues.
Is there a suitable image available for programming into any of the above?
DoG
Re: DiagROM for ST
Post by DoG »
JezC wrote: Sun May 26, 2019 3:22 pm...I have some 27c256 EPROMs (6x 250ns, 2x 150ns) plus a pair of 27c512s kindly supplied by RJ & was wondering if there is a build of DiagROM which will fit into these to diagnose the issues.
You got the github link in the first post. But I'm nice so here you go. Just get the hi and lo of the DiagRom for ST and pop them into the STfm instead of TOS 1.02.
I downloaded the DiagRom cart version and burnt it. Then put them in a cart. So never tried the above but it should work.
Re: DiagROM for ST
Post by JezC »
Thanks for the reply.
When I downloaded the binaries for the ST they appeared to be just too big to fit in a pair of 27c512 - probably just a few K with a couple of strings and a couple of blocks of constant data values so I was hoping there might be a smaller image that would fit in the pair of 512k bit EPROMs I have available.
Slim chance probably, but I felt it worth asking.
Maybe the cart version is smaller? I don't have a board to use the cart versions directly or I'd give that a go.
Return to “DiagROM”
