ALPHA MODIFICATIONS
Re: ALPHA MODIFICATIONS
Forgottenmyname wrote: Thu Sep 27, 2018 4:22 pm If you've kept up, your board should now look a little something like this :)
*real* computing this is :thumbup:
P.s. not done the 16mhz mmu fix as it was optional.
:coolpics: - Looking good.
PaulJ
Post by PaulJ »
Icky, I'm putting in missing pullups on cpu. Your picture with the extra sip pullup pac shows a pullup connected to pin 10 (dtack) but nothing on pin 9 that is identified as needing a pullup. Initially I put the extra pullups in according to your picture but dtack then reads ~680 ohms which means the 1k pullup is ther and the 2.2 k is in parallel with it. Did you get the rw pullup on dtack or am I a marble short of a full deck?
Paul
Looks ok to me...
DTACK is on RP1 (1K) so doesn't need a pull up, Icky doesn't have one on that pin, its RW.
PaulJ
Post by PaulJ »
Your right, I'm one marble short. The prior picture is 90 degree different and I've been looking at it from this perspective.
Paul
PaulJ wrote: Sat Sep 29, 2018 9:32 pm Your right, I'm one marble short. The prior picture is 90 degree different and I've been looking at it from this perspective.
Paul
Hi Paul. Nice to see you working on the board.
Why not open a topic for your pics and experience in the Alpha User Builds section. https://www.exxosforum.co.uk/forum/viewforum.php?f=64
We would like to see where you are and some photos.
PaulJ
Post by PaulJ »
I'll put something up later today.
PaulJ
Re: ALPHA MODIFICATIONS BGACK pull-up
Post by PaulJ »
Do we need another pullup on BGACK pin 12 on processor. Once SJ1 is shorted it connects the 4.7k pullup on GLUE_BGACK (pin 40)? I may just change R150 to 2.2k?
Please advise..
troed
Post by troed »
Is the description for RESET FIX complete? Icky has moved the leg of the resistor which is not in the description, but without it the cut tracks don't really make sense.
edit: Ah, read further down. Also the resistor connects to internal plane I guess. I'm not used to 4 layer boards ;)
PaulJ wrote: Tue Oct 02, 2018 5:54 pm Do we need another pullup on BGACK pin 12 on processor. Once SJ1 is shorted it connects the 4.7k pullup on GLUE_BGACK (pin 40)? I may just change R150 to 2.2k?
Please advise..
There is already a pull-up on it so it resistor is not needed as previously thought..
