ALPHA MODIFICATIONS
troed
Re: ALPHA MODIFICATIONS
Post by troed »
exxos wrote: Tue Sep 18, 2018 6:32 pm
troed wrote: Tue Sep 18, 2018 6:29 pm I'm confused by this being connected to BR.
Its a missing pull up resistor on BR & BGACK.
Yes. But both the pullup fixes are connected to BR, none of them to BGACK :)
Just put the /BGACK resistor in and now /BGACK, /BG & /BR all stay high, do i need to put that link to thepullups?
troed wrote: Tue Sep 18, 2018 6:35 pm Yes. But both the pullup fixes are connected to BR, none of them to BGACK :)
oops... Updated the image...
Forgottenmyname wrote: Tue Sep 18, 2018 6:38 pm Just put the /BGACK resistor in and now /BGACK, /BG & /BR all stay high, do i need to put that link to thepullups?
Check back as I updated a image just...
https://www.exxosforum.co.uk/forum/viewt ... =10#p10084
:headbang: :headbang: :headbang: :headbang:
Looks like I've missed a resistor pack off, as some more pins haven't go pull ups either.. will post fixes shortly....
5 RESISTOR FIX
<shame mode>
Fix for missing pull up resistors on, LDS,UDS,RW,AS,BGACK
5 highlighted pins, wire each to a 2.2K resistor, and wire the other ends to 5V (top end of C21 is 5V)
</shame mode>
Yes, I laughed, after I swore a few times :D
Here's the fix as a photo
Photo of using an extra SIL to provide the 5 extra pull-ups and using the SIL to also provide the BGACK PULL UP FIX
The other wire is the BR PULL UP FIX
White insulating tape to stop any shorts whilst the board is laid flat
Atarian Computing
Post by Atarian Computing »
Icky wrote: Wed Sep 19, 2018 10:55 pm Photo of using an extra SIL to provide the 5 extra pull-ups and using the SIL to also provide the BGACK PULL UP FIX
Ooh, very nice! :bravo:
VIDEO SOCKET FIX
DO NOT SOLDER THE VIDEO SOCKET.
The pinout is wrong and we are working on solutions...
See the PCB fix option in topic below...
https://www.exxosforum.co.uk/forum/viewt ... =19&t=1211
