PSU bracket remake ?
Re: PSU bracket remake ?
I was about to say it looked like a drilled hole with no depth?
What are you editing it in?
PhilC wrote: Mon Apr 22, 2019 7:33 pm I was about to say it looked like a drilled hole with no depth?
RS designspark, Oddly, when I give it depth, shows up in the editor, but it is highlighted green for some reason, but even so when I convert to STL, and view it in the print software, there seems to be a corrupted hole...
I sent it to Icky just, see if he can figure it out. Though as this file does not seem to be a solid model like the ones I created, it might ultimately be easier to start the model again.
Ok, if you get stuck, then I'll re-do it in Fusion360.
Just doing an adaptor board at the mo, that you might see later on.
I've started a new design in DesignSpark for this. I will use sandord files for reference and aid in speeding up the measurements etc :)
Doing a "flood fill" is near impossible in DS :roll: Ended up just copy pasting the hex holes manually to do the fill.
I should be able to merge all that into one block *somehow* :)
yay!
Looking like I'm redundant
Tiny bit more progress at the rear....
Yay slopes!
I have half been thinking about the legs of this thing...
While sandord had these sexy things...
I was more thinking of giving the power supply base basically "wings" which would stick out over the hole, and then have something like a shorter version of the floppy posts.. It would do the same job, but would be a lot easier for printing and design work I think...
Getting complicated this...
Coming along quite nicely.
