PSU bracket remake ?
Re: PSU bracket remake ?
Was this project abandoned ? If so I will try and allocate some time to starting my own version.
Honestly, a lot of distractions have kept me away from this. Feel free to do your own version. Perhaps my Sketchup-version can be of help, I actually got really far with the design, only to end up with hard-to-fix bugs in the model. I concluded that I had to start all over again using Fusion 360 but learning to use that program takes quite so time. I lost focus somewhere while doing tutorials.
No worriessandord wrote: Mon Apr 22, 2019 12:11 pm Honestly, a lot of distractions have kept me away from this. Feel free to do your own version. Perhaps my Sketchup-version can be of help, I actually got really far with the design, only to end up with hard-to-fix bugs in the model. I concluded that I had to start all over again using Fusion 360 but learning to use that program takes quite so time. I lost focus somewhere while doing tutorials.
sandord Just send me the files
I thought I would just print the bottom bit and just see what happens first
To be continued in three hours time I guess...
Looking forward to seeing the results
Dang it!
At least it was early on in the print
Right, there are issues with this thing, as pointed out there is a whole there, but is not there... Now wheres Icky...
Can you see it on the model? Or just in the gcode?exxos wrote: Mon Apr 22, 2019 6:44 pm Right, there are issues with this thing, as pointed out there is a whole there, but is not there... Now wheres Icky...
Just wondering if I can edit it out?
I don't really understand how this 3-D model is put together, is to be more like a drawing than a actual object which I have been used to doing...PhilC wrote: Mon Apr 22, 2019 6:48 pm Can you see it on the model? Or just in the gcode?
I cannot add a hole because there isn't anything solid to draw a hole into...
For example, good hole...
Bad hole (IE no hole at all)
Seems I can drag this hole a bit at time, though it is rather tedious, will see if this works...
