I've tried running CPUs without heatsinks to test things before and they just lock up/crash usually in seconds
How hot does your CPU get then?
You would be better off with a heatsink and no fan than a fan with no heatsink I think.
I had to buy something like that for a Dell laptop before and cut it to shape some gold coloured foil like sticky stuff. The rubber wanna be stuff they fitted at factory was just not good enough.exxos wrote: Mon Aug 13, 2018 10:19 am What I was going to suggest before is use some carbon conductive sheet, its 4x more conductive than copper (think panasonic or samsung make it, cant remember), stick it onto the CPU and fold it to the top metal shielding.. no fan and no heatsink needed then.
I don't think tape is very conductive, and probably a fire riskDrF wrote: Mon Aug 13, 2018 10:34 am If all else fails and you cant get that, what about aluminium tape cut to shape and stacked up?
I don't think glue is very conductive overall, may lose something like 50% dissipation over it, so each "layer" would become less and less effective.DrF wrote: Mon Aug 13, 2018 10:34 am What about thermal adhesives and some copper coins and creative modeling/modification using a file?
I was on about the proper alloy tape you get not the silver coloured crap you find in PoundLand, its a pain in the ass and not easy or cheap to find we use it on turbo piping so I think a CPU might just get away with itexxos wrote: Mon Aug 13, 2018 10:42 amI don't think tape is very conductive, and probably a fire riskDrF wrote: Mon Aug 13, 2018 10:34 am If all else fails and you cant get that, what about aluminium tape cut to shape and stacked up?
Could always use the carbon tape stuff, mount heatsink and fan elsewhere.. Might work using a long length and using the bottom motherboard metal work as a heatsinkProbably melt the plastic case though
Do you have enough room to fit a radial fan? There are fans with 40x40mm and only 10mm in height, popularly used on 3d printheads. You could place the fan next to the cooler and have airflow running through it.mikro wrote: Sun Aug 05, 2018 10:58 pm Unfortunately, that size applies only to the fan (yes, a rather misleading title/description there).
I want it for my Falcon's CT2 card, its heatsink is about 30x30x8mm (sitting on an 030) and I need to attach a fan to it. As you can imagine, the biggest enemy is the height, it must fit below 15mm all together otherwise the keyboard makes inadequate pressure to the CPU. I have room to use a slightly bigger heatsink/fan when it comes to width/length but not height unfortunately.
Thank you very much! I have found such fan here: https://www.ebay.com/itm/142855998003 ... 40x40x10mm, perfect.DrF wrote: Sun Aug 05, 2018 10:44 pm Those style of fans were popular on video cards and motherboard chipsets. I just used to look for "heatsink integrated fan" , "chipset cooler" , "gpu heatsink" , "northbridge cooler" I'm not sure on their proper technical name.
