Okay, I have installed the new replacement cracked resistor & I have installed all the SIPs.
Result: No video output on either TT output or VME graphics output :O
* Notes, I can see the hard drive loading, so I think the machine is running, just without display.
Whats my next move, remove all the SIPS?
Here is a photo of my SIP installation:
Atari TT - Bus errors, advice needed! - SOLVED
Re: Atari TT - Bus errors, advice needed!
Have you got pin 1 of the sips right way ? (normally square pads on pcb) and nothing shorting on the pins to pcb or to each other ?
Okay fixed it lol. The SIPS were all fine, it was the resistors I soldered in to fix the cracked ones. I dunno why but they were causing the no display.exxos wrote: Fri Aug 03, 2018 10:45 am Have you got pin 1 of the sips right way ? (normally square pads on pcb) and nothing shorting on the pins to pcb or to each other ?
*update: Now my floppy drive works
So I'm getting there.. now I just need to work out what to replace the resistors with.. Here is a photo of the location, note the two missing resistors have a C designation, that is odd..
They are c218 and c220. They were: brown green brown silver silver.
I used these: http://au.element14.com/webapp/wcs/stor ... reId=10184
But obviously I must have gone horribly wrong?
What exactly are you looking at ? "C" is normally capacitor not resistor.. Can you find those parts on the diagram ?
Right above those blue thingy mabobs. I've removed them, the designations are there. Click full screen I added a comment and a box around them.
Can you find them on the TT schematic so we can see what they actually are...Steve wrote: Fri Aug 03, 2018 12:59 pm Right above those blue thingy mabobs. I've removed them, the designations are there.
I've had a look but I cannot see them. Maybe Atarian Computing can help with that.
I checked in this persons motherboard photo, on their revision H, they have two of the regular yellow ceramic caps in those places:
https://www.exxosforum.co.uk/forum/viewt ... f=58&t=591
Where mine seemed to have those odd resistors, very strange
Well "old skool" capacitors did have colour codes like resistors.. just I haven't seen any for like 30 yearsSteve wrote: Fri Aug 03, 2018 2:24 pm I checked in this persons motherboard photo, on their revision H, they have two of the regular yellow ceramic caps in those places:
Where mine seemed to have those odd resistors, very strange![]()
If you look online probably a calculator to convert the colours. Assume it be 100nF or something like that.. depends what its connected to..
