TFMSX Arrives
Re: TFMSX Arrives
Maybe this could work: https://uk.rs-online.com/web/p/real-tim ... /6676221p/
Disclaimer: I didn't look at the pinouts, I've just seen them used on modern amiga ram/clock boards.
- Admin sponsor
Re: TFMSX Arrives
its not just the pinouts. Its got to be RP5C01 compatible.
- arkadiusz.makarenko
- Moderator Team
Re: TFMSX Arrives
It could be emulated in arm?terriblefire wrote: Thu Sep 23, 2021 2:39 pm its not just the pinouts. Its got to be RP5C01 compatible.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
Probably well enough yes. We dont need the time to be correct.. just that it ticks.
- Moderator Team
Re: TFMSX Arrives
If precision and keeping time is not important then even clock oscillator and battery would not be required.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
i've basically wired up every spare CPLD pin to the arm now.
Re: TFMSX Arrives
Can be there 12v/+- for soundcards? Like opl4 or carnivore2 (got scc in fpga) cartridge? Also instead of SCC can be there MSXmusic standard?
3x Falcon030 1x TT030 2x ATX-ST 9x A130XE
- Admin sponsor
Re: TFMSX Arrives
no.Matej wrote: Fri Sep 24, 2021 8:34 pm Can be there 12v/+- for soundcards? Like opl4 or carnivore2 (got scc in fpga) cartridge? Also instead of SCC can be there MSXmusic standard?
Re: TFMSX Arrives
I presume the MSX2 uses the ram on the clock chips for config settings then? A bit like the Falcon I guess.
I've googled the chip and it does seem to be available still easily enough but if you can easily emulate it then I guess it's a nobrainer unless you need to use the arm horsepower somewhere else?
- Admin sponsor
Re: TFMSX Arrives
There is a bit of a penalty transferring stuff between the arm and CPLD. Really at this point i'm trying to give us the tools to do what we need.PhilC wrote: Fri Sep 24, 2021 10:24 pm I presume the MSX2 uses the ram on the clock chips for config settings then? A bit like the Falcon I guess.
