I finally got to make this experiment, that was a success : it did power my Atari STe (no add-on, a GOEX floppy emulator instead of a legacy floppy drive), and it did not instantly kill it. I don't have a scope to look at voltage spikes and noises, so I am bound to trust that the USB-PD requirements are enough to not fry my STe little by little
(I was quite confident, as I also dit the same with my thomson MO5, even if I had to buy a bigger charger to have an output voltage of 15V)
Anyway, let's get started :
Here is the charger under test : a small wattage (15 W, 5V at 3A) USB power delivery charger, bought 10€ at a hardware and tools big store.
- 2022-11-11--00-usb-charger-5V-3A.jpg (114.58 KiB) Viewed 2305 times
And here is the schematics and the contraption powered on. The USB trigger is this one
https://fr.aliexpress.com/item/1005003336833794.html (NOT an affiliated link
) ; the 5V->12V converter is from exxos shop, item
#223 (NOT an affiliated link too
) ; I put a very small load (2KOhm resistor + Led) for the sake of testing the voltages. I was too lazy to plug the power resistors I just bought at exxos shop.
- 2022-11-11--01-schematics-and-light-on.jpg (167.82 KiB) Viewed 2305 times
Testing the 5V rail and the 12V, seems ok.
- 2022-11-11--02-test-5V-rail.jpg (131.75 KiB) Viewed 2305 times
- 2022-11-11--03-test-12V-rail.jpg (159.73 KiB) Viewed 2305 times
Now it's time to test (plus I also tested a self made gamepad, that experiment is a fail).
- 2022-11-11--04-ready-to-test.jpg (208.45 KiB) Viewed 2305 times
It's alive ! I let the computer run for a few minutes, no problem. (once again, I don't have a scope, so I cannot check for voltages spikes and noise)
- 2022-11-11--05-alive-0.jpg (126.8 KiB) Viewed 2305 times
- 2022-11-11--05-alive-1.jpg (136.8 KiB) Viewed 2305 times
- 2022-11-11--05-alive-2.jpg (193.45 KiB) Viewed 2305 times
That's all for today, it's time to sleep...
