Recreating the RSVE mod…
Darklord
Re: Recreating the RSVE mod…
Post by Darklord »
That's awesome. :)
sporniket
Post by sporniket »
Looking good...
I don't like the scattered, one-wire connectors J1,J2,J3 and J4, so I also added a 2x3 connectors, with a full row of grounds, so that a ribbon cable would alternate signals and ground. And I also added some mounting holes. I will make the gerbers and send to produce by the end of the week.
Capture d’écran du 2022-11-09 22-29-54.jpg (98.68 KiB) Viewed 1924 times
Darklord
Post by Darklord »
That looks great!
Okay, I'm a klutz at reading these things, so just
to make sure, VCC is +5 volts? (like the original).
Thanks.
sporniket
Post by sporniket »
Does anyone knows where I can get 1.8432 MHz in DIP-14 package cristal oscillators at reasonnable price ? Otherwise I may have to make an adapter to use CMS versions...
sporniket wrote: Sun Nov 13, 2022 9:09 am Does anyone knows where I can get 1.8432 MHz in DIP-14 package cristal oscillators at reasonnable price ? Otherwise I may have to make an adapter to use CMS versions...
@sporniket you could modify the board to accommodate the DIP-8 version (within the DIP-14 footprint) as well as the original DIP-14. That way either can be used.
Darklord
Post by Darklord »
I am a total newb at this stuff so forgive me if this is way off base,
but I gave it a shot:
https://tinyurl.com/3xuvbmes
From the overview: "Most fit into a 14-pos. DIP socket P/N: 133006 ".
Thanks.
sporniket
Post by sporniket »
Ha I forgot to check Jameco, thanks for the reminder. Anyway I already found some other components to buy so I made an order at mouser before you could post.
Darklord
Post by Darklord »
It figures. I actually post something that might have a chance of meaningfully
contributing and it's a day late and a dollar short.
Typical. :lol:
