I also use these erasable ROMs to test combined ROM images I've made, before burning to OTP ROMs. It can get a bit expensive to burn images to OTP ROMs and then find they don't work.Badwolf wrote: Wed Nov 02, 2022 11:10 am If I were you, I'd go to eBay and search for HN27C4096. Look for the PLCC package with the UV window.
WANTED - EmuTOS for STE DUAL TOS from exxos
Re: WANTED - EmuTOS for STE DUAL TOS from exxos
Ironically I have those ROMs as well. Just one of many items which hasn't made it to store yet
Lack is space doesn't help.
One thing to bare in mind is the UV ones are only good for stock machines. They won't be fast enough if the V1 STE booster is used.
Hoarder!exxos wrote: Wed Nov 02, 2022 4:15 pm Ironically I have those ROMs as well. Just one of many items which hasn't made it to store yet![]()
Have you got all the CPLDs and STM32s too?
Only these https://www.exxosforum.co.uk/atari/store2/#0224
@Badwolf
Which of these -> https://www.ebay.com/sch/i.html?_from=R ... =0&_sop=15 will be the best?
@exxos
@exxos
What about TwiSTEr Turbo? (020/24MHz + 8MB alt-ram)One thing to bare in mind is the UV ones are only good for stock machines.
The -10 is a 100ns device. the -85 is an 85ns device. The 85 is probably the better bet, I'd say.arti040 wrote: Mon Nov 07, 2022 7:29 pm @Badwolf
The TwiSTEr has on-board flash memory (4 banks); so - usually - you would not run it with a DUAL TOS on the mainboard, anyway.
@czietz
Indeed!
@Badwolf
I've just ordered 5 of them (there was a pack, the most cost-effective one). They should arrive in 2 weeks.
Indeed!
@Badwolf
@Badwolf
Chips have just arrived. Where to send them?
Have dropped you a note.
