Project: HDMI/DVI out for STFM
Progress on our FPGA cores.
Smonson
Post by Smonson »
I can, but not until tomorrow arvo so about 30 hours away... In the meantime here's where I connected it on mine:
troed
Post by troed »
Here's mine. Bigger pad. Less risk of ripping out a trace when I'm moving the FPGA around ;)
troed wrote: 31 Aug 2018 08:59 Here's mine. Bigger pad. Less risk of ripping out a trace when I'm moving the FPGA around ;)
Should be same line as me then...
I'm on pin 4...
Smonson
Post by Smonson »
Looks good to me. Do you have your USB Blaster ready to go? I'll see if I can whip up a video test.
Smonson wrote: 31 Aug 2018 09:50 Looks good to me. Do you have your USB Blaster ready to go? I'll see if I can whip up a video test.
*somewhere* in a drawer...gosh I couldn't even tell you what software programs the thing, is it in Quartus ? really can't remember :roll:
Smonson
Post by Smonson »
Yep, Quartus :D
I've only used Quartus-II (version 13) so I can't tell you whether any later versions will also work.
Smonson wrote: 31 Aug 2018 10:14 Yep, Quartus :D
I've got 17 & 13 installed :)
Smonson
Post by Smonson »
If you load this file in (use JTAG mode), it'll attempt to display a diagnostic picture at 50Hz.
http://smonson.com/unmanaged/atari/hdmi ... -vsync.sof
Red screen with blue and white vertical bars: no vsync
Green screen possibly with one red horizontal bar: vsync
Thanks.. will give it a try later, have to go out shortly :(
Smonson
Post by Smonson »
No worries! I hope it's nothing serious, my track record so far isn't looking good otherwise :lol:
You can also read vsync off the following 3 pins arrowed in blue.
Return to “FPGA DEVELOPMENT”
