Whoops, I did it again! VIC-20 on the way...
Re: Whoops, I did it again! VIC-20 on the way...
stephen_usher wrote: Wed Feb 16, 2022 3:27 pm Looks similar to this: http://www.sdiy.org/richardc64/vic20/vic01.html
It does.
Hmm, I have the 2 prong PSU connector, so it seems like it's an earlier one, mine seems to have 11 2114 RAM ICs.
OK, looking at what that's doing... One lead goes off to D2 on the VIC chip, with a NOR gate with something else, which is then flipped by the '04 and fed into the RAM /WE line.
So, I'm guessing that if a write is done to a specific address with D2 high then it doesn't get written to RAM. This suggests that whoever did this had a peripheral which sat somewhere and was controlled by a write to that address.
stephen_usher wrote: Wed Feb 16, 2022 3:52 pm OK, looking at what that's doing... One lead goes off to D2 on the VIC chip, with a NOR gate with something else, which is then flipped by the '04 and fed into the RAM /WE line.
Sadly no peripherals that are obvious, or other internal mods. Interestingly, there is a wire that goes off to the CPU, pin 4 which is IRQ. Might try and fully reverse engineer the thing based on the wiring.
Oh, that's the CPU, I thought it was the VIC chip.
stephen_usher wrote: Wed Feb 16, 2022 4:25 pm Oh, that's the CPU, I thought it was the VIC chip.
Yep, the VIC is in the 'boxed' area behind the video and IEC connector for the floppy.
BennehBoy
Post by BennehBoy »
I can't believe how clean that VIC is, nice find.
You may find this interesting:
BennehBoy wrote: Wed Feb 16, 2022 5:04 pm I can't believe how clean that VIC is, nice find.
Yeah, I was a little shocked, it even still had the cardboard shielding inside :)
As for that vid, I watched it the other night :) Definitely a good bit of Commodore history.
Well, I did something crazy tonight. I saved a program to cassette and loaded it back!!!
Here we are loading:
And again after running my simple 2 liner:
I already had the cassette deck with my C64, but it works a treat. Also came up lovely after a scrub with a magic sponge and a plastic wipe :)
Aren't the on screen letters HUUUUUUUUUUUGGGGGEEEE.
Wow! Cassette loading? What will they think of next. Hehe.
stephen_usher wrote: Wed Feb 16, 2022 9:44 pm Wow! Cassette loading? What will they think of next. Hehe.
I know right, it's amazing!!
