It does.stephen_usher wrote: Wed Feb 16, 2022 3:27 pm Looks similar to this: http://www.sdiy.org/richardc64/vic20/vic01.html
Hmm, I have the 2 prong PSU connector, so it seems like it's an earlier one, mine seems to have 11 2114 RAM ICs.
Sadly no peripherals that are obvious, or other internal mods. Interestingly, there is a wire that goes off to the CPU, pin 4 which is IRQ. Might try and fully reverse engineer the thing based on the wiring.stephen_usher wrote: Wed Feb 16, 2022 3:52 pm OK, looking at what that's doing... One lead goes off to D2 on the VIC chip, with a NOR gate with something else, which is then flipped by the '04 and fed into the RAM /WE line.
So, I'm guessing that if a write is done to a specific address with D2 high then it doesn't get written to RAM. This suggests that whoever did this had a peripheral which sat somewhere and was controlled by a write to that address.
Yep, the VIC is in the 'boxed' area behind the video and IEC connector for the floppy.
Yeah, I was a little shocked, it even still had the cardboard shielding insideBennehBoy wrote: Wed Feb 16, 2022 5:04 pm I can't believe how clean that VIC is, nice find.
You may find this interesting:
I know right, it's amazing!!stephen_usher wrote: Wed Feb 16, 2022 9:44 pm Wow! Cassette loading? What will they think of next. Hehe.
