Just to be sure before buying Falcon PSU
Repairs & upgrades.
Re: Just to be sure before buying Falcon PSU
It's just a custom RCA input/output someone made.... While you're working on it I would just desolder and remove them. Then if you want to you can always solder them back on if you like having RCA... I guess you already have the case holes might as well use them :)
Sinis
Post by Sinis »
Thanks again for your reply @Steve: I will take your advice and remove this, but leave the RCA connectors for now.
I'll probably do it next weekend, as I'm so disappointed with the Falcon's current problems that I need to give it some time. I'll do this at the same time as trying to put the old RTC back on, just to see. Incidentally, it's also because I have to work a bit sometimes :)
Thanks again to all for your help.
Users browsing this forum: ClaudeBot, DuckAssistBot and 3 guests
