Indeed. That NCR chip has a theoretical data limit of 1.5MB/s, so the real top speed is around 1.2MB/s.mrbombermillzy wrote: Thu Nov 18, 2021 2:55 pm Of course. Its not a problem at all really. I dont expect the TT needs any kind of ultra/wide/fast/U320 bandwith anyway.![]()
WANTED: Short 50 pin SCSI ribbon cable
Re: WANTED: Short 50 pin SCSI ribbon cable
Check out what my Falcon managed with RaSCSI, does it have a different chip to TT?
I don't know but the hardware specification for the NCR5380 says 1.5MB/s.
See: https://cdn.hackaday.io/files/189748117 ... _May85.pdf
- mrbombermillzy
Maybe surprisingly, no. It uses the same NCR5380.Steve wrote: Thu Nov 18, 2021 6:34 pm Check out what my Falcon managed with RaSCSI, does it have a different chip to TT?
Which begs the question, what is the difference between SCSI and the later SCSI 2 standard that the Falcon uses?
Is it just the form factor, or was the command set changed, in which case, how was the NCR5380 to know the SCSI 2 command set?!
This chip was made in 1986, SCSI 2 wasnt introduced until ~1990.
Anyhow, did you get the TT SCSI drives working @Steve ?
@mrbombermillzy what do you mean, I haven't solved my problem yet
