Mega ST project
Re: Mega ST project
HigashiJun wrote: Wed Oct 27, 2021 8:43 am Results are slightly better, but blitter is disabled by default and there is no way to turn it on.
Yes but that is because the blitter is designed to interface with the ST shifter. For something resembling blitter with a VGA card you need a VGA card that has its own graphics acceleration, like an ATI Mach64. Where as the ET4000 basically just acts as a frame-buffer without any acceleration.
Re: Mega ST project
Post by HigashiJun »
Steve wrote: Wed Oct 27, 2021 11:15 am
Yes but that is because the blitter is designed to interface with the ST shifter. For something resembling blitter with a VGA card you need a VGA card that has it's own graphics acceleration, like an ATI Mach64. Where as the ET4000 basically just acts as a frame-buffer without any acceleration.
Yes, but there is no way IMHO - correct me if I am wrong - to get an ATI Mach work in a Mega ST.
Re: Mega ST project
Or only with a Panther/2...
frank.lukas
Re: Mega ST project
Post by frank.lukas »
Panther/2 (NE2000 + ATI MACH32) + PuPla/2 with Atari Mega ST4 and 68000 CPU no Blitter
Re: Mega ST project
Frank, you have every kind of Atari goodies at home. :)
Nice results with your Mach32.
Cheers.
frank.lukas
Re: Mega ST project
The Nova driver make use of the Blitter in the MACH32 chip.
Re: Mega ST project
Had some time today to test my slim optical drives (Panasonic UJ-875 and TEAC CD-224E).
Both were set as slaves on the Lightning ST IDE port, recognized in HDDriver (had a weird byte swapped name though) but did not work with ExtenDOS 4.
I guess you really have to get a supported drive as per Anodyne Software specifications if you do not want to try miscellaneous drives and spend money for nothing.
Anyway, those two drives were primarily bought for my Amiga 1200 project, so I will make use of them sooner or later.
frank.lukas
Re: Mega ST project
You can try to use the Anodyne Driver Suite with a USB CD/DVD over the Lightning ST. You can use your IDE drives over a USB/IDE Adapter/Controller ...
Re: Mega ST project
frank.lukas wrote: Thu Oct 28, 2021 12:58 pm You can try to use the Anodyne Driver Suite with a USB CD/DVD over the Lightning ST. You can use your IDE drives over a USB/IDE Adapter/Controller ...
Yes, it is also an option but my plan was to fit an internal slim drive in the Mega ST.
I can get ExtenDOS compatible ATAPI drives, but there is definitely no room for 5.25 ones in the pizza box.
frank.lukas
Re: Mega ST project
frank.lukas wrote: Thu Oct 28, 2021 12:58 pm You can use your IDE drives over a USB/IDE Adapter/Controller ...
a option for your slim drives?
