Hello, I have the same board.
officer960 wrote: Mon Oct 18, 2021 12:40 am
1. Is there a comprehensive build guide that I am missing somewhere? I have attempted to find one but not having success.
I am not aware of a step-by-step-noob-proof building guide. You may look at my own thread as I am very slow at building things, and
be aware that I did a contraption of pin sockets on some PLCC sockets because I initially fancied using fpgas on them, so you will be good with just soldering normal PLCC sockets directly :
https://www.exxosforum.co.uk/forum/viewt ... 100&t=3903
So far, I only have overlooked one pin header, you should look at the picture by
@exxos showing the extension port that is meant for flashy clock (if you intend to get one later) here :
https://www.exxosforum.co.uk/forum/viewt ... 486#p67368 (the first pic entitled 'FLASHY CLOCK HEADERS'). I just brigdged the two holes that should be bridged under the DIP64 socket.
Seems correct to me
3. RESET (IC22) (STM6315RBW13F) confirming orientation on this chip.
Under magnification I see one leg is "wider". Datasheet shows that as Pin 1 (ground). Multimeter on the H5 shows shows bottom right pad is connected to ground plane - assuming this is Pin 1 connect point?
Pin 1 VSS Ground
Pin 2 RST Active-low open drain reset output
Pin 3 MR Manual reset input
Pin 4 VCC Supply Voltage
Fortunately, I did not throws my notes about this damned chip.
- 2021-10-18--ic22.jpg (56.38 KiB) Viewed 4914 times
I also struggled to find pin #1 until I noticed the pin that was wider than the others.
PhilC wrote: Mon Oct 18, 2021 12:54 am
That ENIG coating is a pain to solder to, so don't rush soldering as it may seem to have soldered if you do it quickly but I guarantee you'd have a few unsoldered joints on just about every chip.
Personally, I attribute my struggles to the lead-free solder (a SAC blend). Because when I worked with leaded solder on my lynx or my STe, I could see how solder was flowing easily.
After searching for tips, I found
this document, and basically understood that I had to go more slowly.
These days, I count (approximatively the same time as "one mississipi two mississipi etc...") and my cycle is as follow :
- at "1", i put the soldering tip (with a little bit of solder for better head conduction) on the pin and the pad
- at "4", in a swift move, I put the solder lead to add enough solder, then I take away the lead
- just before "8", I remove the soldering tip from the correction, it cool downs after 1 seconds, and I go to the next pad.
This works nicelly for me, excepts for pins linked to the ground, that I still have struggle with. I attribute that to my cheap 25W soldering iron that cannot maintain heat properly at such pins, especially with a conic tip. I plan to upgrade this tool soon.
