Hi thx for replys, here a little video showing the vol is right but i cant change time if i try cant make the enter for accept the change. Regards
https://photos.app.goo.gl/mEN5TgXvPY7g2Fuj8
BOOKMARK THIS PAGE !
TT030 Clock Batterie
Re: TT030 Clock Batterie
Looks like whatever replacement VDI you're using isn't playing well with XCONTROL for a start. It shouldn't allow you to put a lower case 'a' into the AM part.
enito
Hehe no problem with lower was hard to film , but if I write all correct included am or pm in lower or upper can't escape from this , I do enter and nothing . Not sure if the xcontrol is right and I'm testing freemint . Regards
MiNT may be the problem. It may be preventing writing to the protected memory space.
Try booting into standard TOS.
enito
Yes you have reason worked with tos , now the Cr batterie is working the time without power maintain . Now next step for invistigate is the speaker sound . Thx again for the replys really nice group , regards from Chile
enito
Finally corrected the speaker, was a bad positioned in slot. The pin 1 2 area ground and 3 are 5v , now i get sound finally ;)
https://photos.app.goo.gl/EBMGvAP1fQVZgCzC9
Now the time is necesarry 3.6v because the actual retain the time , but if i poweroff the time not advance and continue in the same date hour from last poweroff, anyways THX!
mikro
If you like 1:1 replacements like I do, this is what I installed in my TT and MegaSTEs: https://www.batterycentralmall.com/Batt ... 5242W.html
Users browsing this forum: CCBot, Cyprian, petal [bot], prog99 and 10 guests
