TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
markus0321
Re: TF1230 Beta Interest (Open Source)
Post by markus0321 »
terriblefire wrote: 01 Sep 2021 20:20
Danoo wrote: 01 Sep 2021 20:03
Ordered my parts straight off the 1230 Schematic file in Eagle that file is showing a XC95288XL as the CPLD
Ah sorry.. its the same footprint and its pin compatible.. you'll just need a different jed
Maybe it would be possible to somehow convert the Jedec file from xc95144 to Xc95288?
I made the same mistake as Danoo but unfortunately I have already soldered the chip to the board, eh ... :(
I can compile for 288... let me sober up first.
markus0321
terriblefire wrote: 18 Sep 2021 00:15 I can compile for 288... let me sober up first.
Thanks a lot! I will wait patiently :)
Aeberbach
Post by Aeberbach »
Should TF1230 boot with no memory attached? Was going to start building, thought maybe I should get the CPLD on and programmed, 030, passives and clocks, and check that first.
it will .. OS just wont find any RAM
Aeberbach
Post by Aeberbach »
Thank you sir!
Exciting times for the A1200. I have a 1D4 that has been waiting for keycaps for the new mech keyboard to be ready for the lid to be screwed down for the first time in a year. Yesterday they arrived, everything was plugged in and turned on. It was a very happy moment when it booted again from the HD after reinstalling 3.1.4. So looking forward to putting the A1230 in there too!
markus0321
markus0321 wrote: 18 Sep 2021 00:18
Hehe. Now I couldn't sleep ;-) and the first thing I did in the morning was reading the forum. Let me know when you will be able to compile this batch under 288 because I'm not so patient anymore? ;-)
Alpha for the 288 CPLDs....
tf1230r1_main_top_288.zip
EDIT: Since i dont actually have a 1230 with a 288 CPLD its untested.
markus0321
terriblefire wrote: 18 Sep 2021 11:39 Alpha for the 288 CPLDs....
Wow! I already have the entire TF1230 soldered, I'm programming the CPLD right away and I'm starting to run it and test it.
Thanks a lot for the quick help. You are great
markus0321
markus0321 wrote: 18 Sep 2021 13:10
Not working...
There is only a black screen on the diag-rom. I checked the soldering under a microscope and it looks good. My A1200 is rev 2b will try to do timingfix, if it doesn't help, I will check it on version 1.d4 1.d1 .....
Return to “TF330”
