The subject says it all! I know the Falcon can be picky about which CF cards it will actually accept for the IDE to CF converter, so can anyone recommend a brand / model of card to buy that will work?
Cheers,
Rich
Which CF cards work with the IDE to CF converter for Falcon?
photonstorm
Re: Which CF cards work with the IDE to CF converter for Falcon?
Sandisk are normally the ones which are less picky than other brands. I use a sd2ide adapter in mine.
derkom
Seconded. After running into way too many CF cards that just wouldn't play nice, I started using one of these (random Amazon link, it's a Chinese product you can find anywhere). Haven't had a single problem since.
Oddly I've never had issues, but maybe I only have decent CF cards :) I recommend anything by Transcend, they're the bee's knees.
thtna71
And an additional question: what's the maximum size that will be accepted by a falcon if I use a compact flash card ? 4gb ?
As far as I know you could put pretty much any size you want in it, as long as you partition it to the TOS standards, ie; 1gb max size for the falcon. There may be limits to the maximum amount of partitions too. Honestly I'd recommend a 4gb transcend 'industrial' CF card as it uses more resilient memory.
pixelpusher
You might consider durable SLC based CF cards like the Transcend Industrial 2GB CompactFlash I card - (TS2GCF300) - which works in the Falcon.photonstorm wrote: 25 Mar 2021 23:50 The subject says it all! I know the Falcon can be picky about which CF cards it will actually accept for the IDE to CF converter, so can anyone recommend a brand / model of card to buy that will work?
Cheers,
Rich
thtna71
Thanks for the help guys.
Users browsing this forum: ClaudeBot, trendiction [bot] and 5 guests
