BOOKMARK THIS PAGE !
STL for the inexpensive ST2VGA?
The place to discuss & share your 3D models or printable parts!
Calab
Post by Calab »
Hey all!
Just wondering if there is an STL that fits the version 5 of the ST2VGA that I just received today.
Calab
Re: STL for the inexpensive ST2VGA?
Post by Calab »
I knew there had to be one... I just didn't have any luck with my searches. THANK YOU!
Was right at the top as well :lol:
Calab
Post by Calab »
I was able to finally get a 3D print done... Just couldn't get it to go on my filament printer so I printed with my resin printer.
Found a couple of small issues... Don't know if it's just how I printed it or what, but I thought you might want to know.
The opening for the jumper on top isn't wide enough. The pins interfere with closing the cover... pressing on the back side of the cover.
Also couldn't get my audio plug to fit with the cover in place.
Take care!
I'm confused why you have 6 pins there, when there is only supposed to be 3 ?
I think the upper "pins" are merely reflections off the upright parts of the right-angled header.
Right angled headers can have different heights off the PCB. I'm guessing that the 3D printed case was designed for one of the "low rise" right-angled headers and he's fitted the more usual height DuPont one.
DoG
Post by DoG »
Calab wrote: 22 Aug 2021 04:19.. Found a couple of small issues... Don't know if it's just how I printed it or what, but I thought you might want to know.
The opening for the jumper on top isn't wide enough. The pins interfere with closing the cover... pressing on the back side of the cover...
Read the thread where you find the stl files. The pins got solder on the other side on the board by misstake.
mikelord68
Post by mikelord68 »
Hey gang, this link appears to be dead or broken. Any ideas?
Misdirected Request
The client needs a new connection for this request as the requested host name does not match the Server Name Indication (SNI) in use for this connection.
Apache/2.4.54 (Ubuntu) Server at exxosforum.co.uk Port 443
mikelord68 wrote: 28 Aug 2022 15:57
Misdirected Request
Works for me. But just change host to forum in the URL..
Return to “3D MODELS”
Users browsing this forum: CCBot and 44 guests
