H5C1 BOM
H5C1 BOM
The REV H5C1 is assembled as shown in the image below. There are some parts which still need fitting but nothing much overall needed to get it up and running.
Most parts listed should be available in the store or from a donor machine.
ESSENTIAL (excluding main chips)
A two pin jumper for the ROM select on the left of the board.
https://www.exxosforum.co.uk/atari/store2/#0158
JUMPER LINKS
https://www.exxosforum.co.uk/atari/store2/#0188
13 PIN DIN VIDEO CONNECTOR
https://www.exxosforum.co.uk/atari/store2/#0157
The 32MHz osc.
https://www.exxosforum.co.uk/atari/store2/#0006
72pin simm socket.
https://www.exxosforum.co.uk/atari/store2/#0056
RESET SWITCH
https://www.exxosforum.co.uk/atari/store2/#0114
FLOPPY POWER LEAD
https://www.exxosforum.co.uk/atari/store2/#0211
ROM
https://www.exxosforum.co.uk/atari/store2/#0054 (of course select correct language!)
FLOPPY RIBBON CABLE
Your parts bin or the "usual outlets" .
4MB 72 PIN SIMM
CONNECTORS
DB25 MALE (RS232)
https://www.exxosforum.co.uk/atari/store2/#0134
DB25 FEMALE (PRINTER)
14 PIN DIN EXTERNAL FLOPPY CONNECTOR
https://www.exxosforum.co.uk/atari/store2/#0100
CARTRIDGE PORT
https://www.exxosforum.co.uk/atari/store2/#0203
DMA PORT DB19
https://www.exxosforum.co.uk/atari/store2/#0084
68K SOCKETS ( if you plan to use addons )
https://www.exxosforum.co.uk/atari/store2/#0038
CHIPS
68HC000 CPU
https://www.exxosforum.co.uk/atari/store2/#0092
ACIA x2
https://www.exxosforum.co.uk/atari/store2/#0105
WD1772 FLOPPY IC
https://www.exxosforum.co.uk/atari/store2/#0087
MMU
https://www.exxosforum.co.uk/atari/store2/#0075
https://www.exxosforum.co.uk/atari/store2/#0080
GLUE
https://www.exxosforum.co.uk/atari/store2/#0005
https://www.exxosforum.co.uk/atari/store2/#0081
SHIFTER
https://www.exxosforum.co.uk/atari/store2/#0102
DMA
https://www.exxosforum.co.uk/atari/store2/#0004
https://www.exxosforum.co.uk/atari/store2/#0164
YM2147 AY8910 SOUND IC
https://www.exxosforum.co.uk/atari/store2/#0103
MFP PLCC
https://www.exxosforum.co.uk/atari/store2/#0148
BLITTER - (Yeah right! :lol: )
https://www.exxosforum.co.uk/atari/store2/#0002
RECOMMENDED & AVAILABLE ADDONS
TOS206 DECODER
https://www.exxosforum.co.uk/atari/store2/#0172
TRUDIE IDE INTERFACE
https://www.exxosforum.co.uk/atari/store2/#0206
OTHER OPTIONAL STUFF
32.768 OSC RTC
https://uk.farnell.com/citizen-finedevi ... 7-00001003
1220 BATTERY HOLDER
https://www.mouser.co.uk/c/power/batter ... lectronics
RTC CHIP DS1315
https://www.mouser.co.uk/c/semiconducto ... V&active=y
1.44 FLOPPY MOD GAL
https://www.exxosforum.co.uk/atari/store2/#0227
Of course the chips themselves are not supplied.
There might be other items I have currently missed. If anyone spots anything than let me know and I will update the list above.
StealthGunner385
Re: H5C1 BOM
Post by StealthGunner385 »
Pardon the relative newbness of the question, I have followed the project with great interest, but perhaps not to the greatest detail.
I'm planning to populate my freshly ordered H5C1 with salvages from a broken-motherboard 1040STF (no blitter).
While looking at the BOM, I noticed the ROM link leads to the TOS 162/206, the STE dual-ROM.
Is this as intended, or are the TOS 104/206 ROMs more suitable?
I realize that in either case, the TOS decoder board might be necessary to fully utilize 206 ROMs.
Re: H5C1 BOM
@StealthGunner385 the Tos1.04/2.06 would be a better choice and as you say, you'll need a decoder board for 2.06 to work :)
StealthGunner385
Re: H5C1 BOM
@PhilC thanks for confirming what my gut had told me. Considering the donor board's original ICs, looks like it's time to get a new CPU, MFP, DualTOS and Decoder.
Re: H5C1 BOM
@StealthGunner385 ST chipset only supports TOS104,TOS102 DUALTOS, but I don't suggest them as I am actually discontinuing that combination. It's why I am suggesting the TOS104, TOS206 ROMs. Then at least if you decide to use the decoder board, you already have TOS206 ROM ready for it.
Bikerbob
Re: H5C1 BOM
Post by Bikerbob »
Assuming an STF donor.
And it is working.
What parts do I need outside the donor. I know there are some header pins. The 72pin socket for ram would be a must?
What else can I NOT get from the donor?
James
Bikerbob
Re: H5C1 BOM
Post by Bikerbob »
Does this seem right?? any input is appreciated.
A two pin jumper for the ROM select on the left of the board.- could be local sourced
JUMPER LINKS
https://www.exxosforum.co.uk/atari/store2/#0188 - could be local sourced.
https://www.exxosforum.co.uk/atari/store2/#0157 - donor board
The 32MHz osc.
https://www.exxosforum.co.uk/atari/store2/#0006 - donor board??
72pin simm socket.
https://www.exxosforum.co.uk/atari/store2/#0056 - exxos store - easiest source?
RESET SWITCH
https://www.exxosforum.co.uk/atari/store2/#0114 - donor board for 1 - does the board need 2?
FLOPPY POWER LEAD
https://www.exxosforum.co.uk/atari/store2/#0211 - scraps local or exxos store
ROM
https://www.exxosforum.co.uk/atari/store2/#0140 - must be sourced from exxos store
FLOPPY RIBBON CABLE
Your parts bin or the "usual outlets" . - local
4MB 72 PIN SIMM
DB25 MALE (RS232)
https://www.exxosforum.co.uk/atari/store2/#0134 - donor board
DB25 FEMALE (PRINTER) - donor board
14 PIN DIN EXTERNAL FLOPPY CONNECTOR - donor board
CARTRIDGE PORT
https://www.exxosforum.co.uk/atari/store2/#0203 - donor board
DMA PORT DB19
https://www.exxosforum.co.uk/atari/store2/#0084 - donor board
https://www.exxosforum.co.uk/atari/store2/#0038 - local
68HC000 CPU
https://www.exxosforum.co.uk/atari/store2/#0092 - ahhh exxos store, not a 68pin dil.. got it! ;) (edited)
ACIA x2
https://www.exxosforum.co.uk/atari/store2/#0105 - donor board
WD1772 FLOPPY IC
https://www.exxosforum.co.uk/atari/store2/#0087 - check the chip.. but if not 1772 then should change I assume
MMU
https://www.exxosforum.co.uk/atari/store2/#0075 - donor board
GLUE
https://www.exxosforum.co.uk/atari/store2/#0005 - donor board
SHIFTER
https://www.exxosforum.co.uk/atari/store2/#0102 - donor board
DMA
https://www.exxosforum.co.uk/atari/store2/#0004 - donor board (does stfm need to check for bad dma?)
https://www.exxosforum.co.uk/atari/store2/#0103 - donor board
MFP PLCC
https://www.exxosforum.co.uk/atari/store2/#0148 - PLCC not on STF so exxos store.
https://www.exxosforum.co.uk/atari/store2/#0002 - STFM - no blitter.
TOS206 DECODER
https://www.exxosforum.co.uk/atari/store2/#0172 - exxos store
https://www.exxosforum.co.uk/atari/store2/#0206 - exxos store
DoG
Re: H5C1 BOM
Post by DoG »
You don't need two reset switches and you can use 68k processor in DIL package if you want to. You just have to solder in a socket for it.
The MFP is DIL on most Ataris (all?) and not PLCC as on H5c1 so nothing you can find on a donor board.
Re: H5C1 BOM
The ESSENTIAL list is what you need from my store.
while you can reuse your old CPU, I really would not bother and just get one of the 68HC000 CPU's from my store.
Re: H5C1 BOM
Whats required now to implement the S2 Midi Synth? do we still need the amp board or is it good to go?
Return to “H5 C1 USER BUILDS”
